GT35R, Use the built in restrictor, or buy one from ATPturbo
Old 01-17-2007, 01:56 PM
Topdawgg's Avatar
Default GT35R, Use the built in restrictor, or buy one from ATPturbo
mine is identical to this, so what should i do, order a restrictor from ATP, or just run a feed line and then a fitting right to this?
Old 01-17-2007, 02:12 PM
LSVTECTURBO-EG's Avatar
Default Re: GT35R, Use the built in restrictor, or buy one from ATPturbo (Topdawgg)
buy the gt install kit, comes with everything you need to rock.
Old 01-17-2007, 02:13 PM
Topdawgg's Avatar
well, what all does it come with, cause i have most of the stuff already i think
Old 01-17-2007, 02:16 PM
N20civicB18's Avatar
buy a restrictor
Default Re: (Topdawgg)
it comes with the drain fitting adapter, gt turbo use a smaller one, it comes with the banjo fittings for the water kines, and the oil inlet fitting which does have a restricter in it. you can also buy all of this stuff seperate if you have some of it.
Old 01-17-2007, 02:19 PM
Topdawgg's Avatar
Default Re: (LSVTECTURBO-EG)
yea.. i just saw what it comes with
thing is, i just ordered an oil line kit from stan at Fast-Turbo.com
his kit has the GT return flange, the only thing i dont have is the inlet/outlet fitting for the coolant lines, but im sure any hydraulic shop will have something to thread into that..
Old 01-17-2007, 02:22 PM
yeah you can make something work.
Old 01-17-2007, 03:12 PM
Quickgti1.8t's Avatar
my 35r cam with a restrictor, but i still bought the one from ATP
Old 01-17-2007, 03:24 PM
Topdawgg's Avatar
and you have been running it for a while with no problems?
Old 01-17-2007, 04:03 PM
i my honda
Global Mod
White Smoke's Avatar
The general consensus now is to just add another just to be safe
Old 01-17-2007, 04:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">and you have been running it for a while with no problems?</TD></TR></TABLE>
over 5k, and the VW's have twice the oil pressure as you guys
Old 01-17-2007, 04:43 PM
93supercoupe's Avatar
Default Re: GT35R, Use the built in restrictor, or buy one from ATPturbo (White Smoke)
yeah, mine also came with one.
It looks to me that the one in the turbo wouldnt restrict as much oil as the turbo needs, so whats the point of having it all in there?
Old 01-17-2007, 05:12 PM
Topdawgg's Avatar
Default Re: (Quickgti1.8t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickgti1.8t &raquo;</TD></TR><TR><TD CLASS="quote">
over 5k, and the VW's have twice the oil pressure as you guys</TD></TR></TABLE>
well then it could be benefitial to you to have both.. if you have more pressure
Old 01-17-2007, 06:05 PM
Bailhatch's Avatar
you sure?
I helped a buddy with his gt35 1.8t and i dont remember crazy high oil presure.
Old 01-17-2007, 07:25 PM
a1320addict's Avatar
Default Re: (Bailhatch)
definently run the .035" restrictor, end thread.
Old 01-17-2007, 11:02 PM
eg:R's Avatar
why use a restrictor if it already built in?? i don't get it
Old 01-18-2007, 05:48 AM
HybridKOOP's Avatar
Default Re: (eg:R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg:R &raquo;</TD></TR><TR><TD CLASS="quote">why use a restrictor if it already built in?? i don't get it</TD></TR></TABLE>
I agree with you.
Old 01-18-2007, 06:59 AM
Default Re: (HybridKOOP)
The GT series don't need a lot of oil, the restrictor built-in to the housing may not be adequate. This happened with me on my old 28RS, it's $12.00 insurance.
torqueless
12-08-2005 09:04 AM
blkhatch92
10-13-2005 10:31 AM
rwcdrums
03-29-2005 11:03 PM
ASHY-ELBOW
10-27-2002 03:07 PM
1.8EG-T
06-13-2002 02:48 PM
Quick Reply: GT35R, Use the built in restrictor, or buy one from ATPturbo
