FiveOmotorsport EV14 1200cc injectors
Old 11-24-2012, 11:11 AM
DFW
DFW's Avatar
Default FiveOmotorsport EV14 1200cc injectors
Anyone running these injectors or reviews? I have done a few searches on these and so far so good (except for a couple bad reviews on WRX/STi motors), but not much on K-series/1200cc specifically.
http://www.ebay.com/itm/4-Honda-K20-...019#vi-content
http://www.fiveomotorsport.com/product-search/?v=3362
Use for highly modified K20 and K24 - 4 cylinder engines, Hyundai Tiburon/Genesis 2.0/3/8, Nissan 350 and 370Z, Skyline GTR. (This injector can be custom fitted to many applications. See other listings or call for specific fit).
FLOW CHART: Each set is sold with a complete flow-data chart indicating individual dynamic and static flow rates at 3, 3.5, and 4 BAR at 25%, 50% and 100% for each injector, along with dead time (latency) at 14 volts. Flow matching was done with industry-standard equipment of the highest quality.
The tests were performed at varying temperatures to achieve realistic results.
Our injectors are custom-milled from brand new American/German/Japanese-made fuel injector "cores" in large-quantity batches to achieve the highest quality product.
The resulting sets are all-fuels rated; including gasoline (MTBE), and E-85. The finished injectors are then flowed and inscribed with a control number. Data is recorded for each injector. They are then hermetically-sealed and placed in matched sets ready for shipping.
You don't get this kind of technology from an OE injector.
You receive a complete set of fuel injectors - ready to install in your modified engine - complete with all orings and/or rubber grommets.
Flow Rates: (Actual flow rates may vary set to set but not more than 0.5-1.0%).
1200cc/min at 43.5 PSI (3.0 BAR)
1305cc/min at 50.8 PSI (3.5 BAR)
1410cc/min at 58.0 PSI (4.0 BAR)
Complete static and pulse flow rates delivered with each set.
Latency (Dead Time): 1.0ms at 14 volts (Complete table sent with set).
Resistance: 11.8-15.5 Ohms, high resistance
Voltage: 8-15 Volts, Nominal 13.5 Volts
Amperage: 1.0 Amps
Dead Time: 1.0 ms at 14 volts
Excellent atomization for medium compression, single- and multi-valve engines.
Pressure: Min. 36 PSI (2.5 bar), Max. 101 PSI (7 bar)
Surface finish: Black composite
Easy tuning and accurate compensations
Old 11-24-2012, 11:49 AM
Who is Mr Robot?
wantboost's Avatar
Default Re: FiveOmotorsport EV14 1200cc injectors
Exact same thing as injectord dynamics... they are nothing more than bosch ev14 injectors with a flow sheet
Old 11-24-2012, 02:54 PM
Moderator in Chief
Muckman's Avatar
Im running Five0motor 1600cc Bosch EV14 injectors on E85. Love them.
Old 11-24-2012, 10:13 PM
artie89's Avatar
any more reviews
Old 11-25-2012, 01:23 AM
Who is Mr Robot?
wantboost's Avatar
You can't go wrong with Bosch ev14 injectors... spray pattern and atomization is amazing
Old 11-25-2012, 07:39 AM
DFW
DFW's Avatar
Thanks. How long have you been using them?
I'm running the DeatschWerks 1300cc Bosch EV14 currently and cannot get the AFR at idle to stop hunting from rich to lean. Something about the low pulse-width on the injectors.
Here is what my tuner said
They have extremely poor low pulsewidth performance. Idle quality is absolutely horrible and low throttle closed loop performance is wanting. This isn't me just talking **** either -- I love DW's fuel pumps and run them in both of my Hondas because they're awesome pumps. But I've tuned multiple people with those DW1300's and every time the story is the same (not to mention we've personally tested a set to compare to a set of ID1k's).
And here is the thread on exactly what my car is doing on the DW1300's http://www.8thcivic.com/forums/force...-showdown.html
Old 11-25-2012, 02:21 PM
Man U FTW
Schister66's Avatar
Glad to hear these are decent...i've been looking at them for my STi, but i've heard a few iffy reviews. Are the side-feeds good also?
Old 11-25-2012, 04:24 PM
mtber's Avatar
I have no experience with the five0 injectors.
ID's would be my choice for the extra money.
I have used FIC's injectors and not had an issue.
FIC dealers including us are running a black friday weekend special on their injectors. 15% off for 525-900cc and 10% off for 1100cc or 2150cc injectors.
(Contact via the number in my signature if your interested in the sale price)
Old 11-25-2012, 04:34 PM
Moderator in Chief
Muckman's Avatar
I’ve been running mine for over a year. I’m able to idle relativity solid at 1,000rpm at 14:1 AFR. I say relatively because I have large cams that pull a low vac at idle.
ID needs to have a middle option between 1000cc and 20000cc injectors.
Old 11-25-2012, 08:43 PM
civic efb16's Avatar
how much power are you making
Old 11-25-2012, 08:44 PM
Moderator in Chief
Muckman's Avatar
600 on E85. See build thread in sig.
Old 11-25-2012, 10:56 PM
extremeracer's Avatar
I run Five0 1600cc EV14's on my 84x89 LS/Vtec, they run impressively smooth on pump gas and ofcourse even better on E96
Old 11-26-2012, 04:41 PM
EJ1_Ex's Avatar
had a buddy who ran these injectors and they failed after a few dyno pulls.
Old 11-26-2012, 05:45 PM
ashb82's Avatar
i tuned a car with them i liked them. if i go bigger it will be fiveo
Old 11-30-2012, 06:27 AM
DFW
DFW's Avatar
What exactly failed on the injectors? Did it just stop working?
Old 12-01-2012, 02:32 PM
Tony the Tiger's Avatar
I want to know too... Injectors don't just die, especially when they are based off from reliable proven cores.
Most of the time, it's probably debris in the fuel line (e.g. new custom fuel system with new lines, fittings, etc..), and then they clog up the injector and they stop working or starts leaking internally. Over the years, I have a habit of priming and flushing the system out without the fuel rail attached whenever I install a new pump, a new line, etc...
Old 12-01-2012, 03:42 PM
LightningTeg's Avatar
These seem like a good choice that are not ready to jump to 2000's. I'll be trying there 1400's out soon.
Old 12-01-2012, 09:32 PM
mtber's Avatar
I am sure they are working on something :-)
Old 12-01-2012, 10:23 PM
Who is Mr Robot?
wantboost's Avatar
These are all Bosch ev14 injectors.. just FYI
Old 12-02-2012, 07:24 AM
DFW
DFW's Avatar
I can't stand the idle/driveability on these Deatschwerks 1300's. Looks like I'll be ordering a set of FiveOmotorsports 1200cc for Kseries in the up coming week. I'll keep this updated.
Old 12-02-2012, 07:29 AM
DFW
DFW's Avatar
Just saw ID is coming out with 1300's!
Old 12-02-2012, 11:49 AM
tepid1's Avatar
Furthest thing from the truth. They are NOT the same. Not even close.
Old 12-02-2012, 12:20 PM
bgdriver's Avatar
Care to explain how two injectors with the same core and flow capabilities are "not even close" to each other? Not hating, legitimately want to know.
Old 12-02-2012, 12:39 PM
Who is Mr Robot?
wantboost's Avatar
They are all based on the ev14
Each company modifies them
Old 12-03-2012, 03:28 AM
tepid1's Avatar
Read up.
http://www.injectordynamics.com/
One of the most informative web sites out there!
vtec.dc2
02-27-2008 04:52 PM
Black R
08-07-2004 08:01 AM
1.8t
10-26-2003 07:32 PM
superduperman
09-13-2003 12:37 AM
Quick Reply: FiveOmotorsport EV14 1200cc injectors
