e-manage interaction light suppose to constantly blink?
Guest
Posts: n/a
when i put the emanage in check mode by just turning the car on, the lights come on but none of them blink. but with my car running, the interactive light (laptop connected) not the active light but the interactive light constantly blinks. is it suppose to do this? i thought this light comes on when a laptop is connected.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">Whenever it flashed or anyhting. there was generlaly something wrong</TD></TR></TABLE>
interactive or active led?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">Oh oaky. in taht case the interactive light always stayed solid. laptop hooked up or not.</TD></TR></TABLE>
always stayed solid sounds as bad as mine constantly blinking...
we need some e-manage gurus
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NinjaTurtles »</TD></TR><TR><TD CLASS="quote">It constantly blinks while the car should be running</TD></TR></TABLE>
but why would they make it so it constantly blinks doesnt make sense. its annoying me i guess i better put some tape over it hah.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 »</TD></TR><TR><TD CLASS="quote">find the h-t member "The Shodan". He will know for sure. I promise.</TD></TR></TABLE>
is he a e-manage master? heh ill pm him thanks..
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyro_assassin »</TD></TR><TR><TD CLASS="quote">mine kinda flashes like a cable modem in use. really fast jittery flashes not consistent with any pattern. i too was wondering what that was</TD></TR></TABLE>
well hmmm, mine is consistent.
flash..flash..flash..flash..flash..
I have emanage. And YES the "interaction" light does BLINK in a steady pulse. This is because i was told there is no connection to comuter, hence the USB port. Not 100% sure.
But the main thing is the active light, the GREEN light. When you give it gas, the Active LED should TURN green and when you let off gas it will go to orange. If the active light is doing what i am saying, then it is working fine.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l337hxr »</TD></TR><TR><TD CLASS="quote">I have emanage. And YES the "interaction" light does BLINK in a steady pulse. This is because i was told there is no connection to comuter, hence the USB port. Not 100% sure.
But the main thing is the active light, the GREEN light. When you give it gas, the Active LED should TURN green and when you let off gas it will go to orange. If the active light is doing what i am saying, then it is working fine. </TD></TR></TABLE>
alright i guess everything is okay then. thanks
i believe if youre below 1000rpms then its orange.
grngsr01
Mar 25, 2002 06:09 AM
