d16z6 head with d15z1 bottom end combo. ptw clearance??
Old 08-29-2016, 01:09 AM
EG-SIXV-TEC's Avatar
Default d16z6 head with d15z1 bottom end combo. ptw clearance??
hello hondatech I'm building an oem vitara build aka as the but with oem parts d16z6 head with a d15z1 bottom end for boost.
many guys said that this will end up like a 7. to 1 low compression or a 8 to one compression setup. i will run this setup for turbo. possible high boost with a good tune.
i have a d16z6 head that is oem spec new fresh seals etc build. arp head studs and bolts. i will use the d15z1 bottom end
full crank assembly with oem coded bearings. the crank got mic and was all standard shop said it was okay.
the engine was a high milage everything is ok but the bore is close within the service limits the shop told me a hair over.
i haven't measure the piston to find the piston to wall clearance but is this acceptable? if the bore is service limits maybe hair over?
heat boost is that ok with using the oem pistons. how much ptw cleanse i can use with this.
i want to oem low comp build what would be this be acceptable for ptw cleanace?
thanks...
Old 08-29-2016, 09:56 AM
Default Re: d16z6 head with d15z1 bottom end combo. ptw clearance??
BUMP…….. DOES ANYONE KNOWS?????
Old 08-29-2016, 11:14 AM
Dark_Teg's Avatar
Your pistons will come with a spec sheet that will show you what clearance is required, the spec sheet should also give you the ring gap recommendations etc...
Old 08-29-2016, 01:16 PM
TravisBiggie's Avatar
7:1 or 8:1 is such low compression. Don't do that. ( I don't know **** about single builds) I was told vitaras will put you around 9:1?
honestly, 9:1 to 10:1 is best for turbo IMO. Low compression is an old myth.
Also..... Piston to wall clearance is determined by the material your piston is made from... Vitaras are CAST I would say? If so.... standard .002" P2W clearance is appropriate..
Old 08-29-2016, 01:17 PM
Define a hair over..... did they actually check p2w...........? if so....... what is it...........?
Old 08-29-2016, 01:18 PM
you're coming here asking us a question when we don't even have the information needed to answer your question........... figure out the P2w and return..........
Old 08-30-2016, 10:43 AM
i haven't asked for the ptw clearance but he told me that it is its within std.
but the bores are loose side that the top of cylinder number one is wider than bottom. is that bad.service limit.
i posted a pic thats the specs i got for now
cylinder number one is the top in order 1234 bottom.
Old 08-30-2016, 08:27 PM
B and B's Avatar
His diagram is more readable than the one I made last blueprint.
By my translation OP isn't using Vitaras.
Old 08-31-2016, 12:27 AM
its not a vitara/eagle build d16z6 but supposed to equal to as with d16z6 head/d15z1 bottom end oem parts. correct me if I'm wrong this setup suppose to be something like that. as low compression wise but with the oem counterparts with out vitars/h beam eagle rods.
any one know if what i can use for ptw clearance? with oem d15z1 pistons? is this specs ok? for boost?
replacement pistons i can use.
lemontit
10-25-2014 10:01 AM
Slosc2
10-26-2013 08:22 PM
taytay
01-08-2012 09:57 PM
DCSportEJ1Civic
05-30-2007 10:33 PM
d16dcoe45
09-19-2006 12:44 PM
Quick Reply: d16z6 head with d15z1 bottom end combo. ptw clearance??
