Apexi AVC-R map sensor
Old 04-14-2007, 02:15 AM
* B A N N E D *
Legion's Avatar
Default Apexi AVC-R map sensor
Car is currently running on Crome w/ a GM 3 bar.
I've been looking into EBC's and the AVC-R caught my eye. However, I've noticed that it comes with it's own MAP sensor. Is this sensor only for use by the AVC, or can I completely replace my GM sensor with the APEXi sensor?
Old 04-14-2007, 05:31 AM
HiProfile's Avatar
Default Re: Apexi AVC-R map sensor (Semtec)
If you did use it, you'd have to retune with it. Most other sensors have better vaccum curves than the GM sensor, meaning partial throttle would act up.
Old 04-14-2007, 06:31 AM
Rus1an's Avatar
Default Re: Apexi AVC-R map sensor (HiProfile)
I also like to know if I could use the map sensor that comes with the ACV-R to actually run my car on.
Old 04-14-2007, 10:47 AM
Moderator
TheShodan's Avatar
Default Re: Apexi AVC-R map sensor (Rus1an)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rus1an &raquo;</TD></TR><TR><TD CLASS="quote">I also like to know if I could use the map sensor that comes with the ACV-R to actually run my car on.</TD></TR></TABLE>
that Map sensor is a DENSO 3 bar map sensor used on the Greddy E-manage (Pressure sensor) as well as the Power FC. They are the same part number. From my experience with both E-manage and Power FC, I've only used that map sensor in conjunction with the STOCK map sensor. meaning that you would use BOTH to incorporate both vacuum and positive pressure. I'm not sure if it can be used independently like a GM map sensor. best bet is to call Apex'i to find out if this is indeed the case. You'll more than likely need to know the voltage signal in order to calibrate your Crome system
woojdm
06-09-2009 08:54 PM
Civicman86
09-21-2006 08:25 PM
abmerop18
05-28-2006 07:45 PM
adeihl
09-02-2004 04:21 AM
Quick Reply: Apexi AVC-R map sensor
