What happens when my closed loop is closed?
Old 11-22-2006, 09:36 PM
motormike40's Avatar
Default What happens when my closed loop is disabled?
hey Im looking into getting a quick BIN file so I drive my car. I found one map, but it says the closed loop is disable. How will this affect my car?
Modified by motormike40 at 10:48 PM 11/22/2006
Old 11-23-2006, 06:01 AM
coneheadsracing's Avatar
Default Re: What happens when my closed loop is disabled? (motormike40)
If i remember right. Closed loop is for cold start, then it goes into open loop once warmed up. So, if you live in a colder climate might be a pain. Not 100 percent sure thoguh.
Old 11-23-2006, 06:22 AM
atec's Avatar
Closed loop means that the ecu is correcting/adjusting fuelvalues(injector duration) up to the stoichiometric ratio 14.7:1 or lambda 1 with by trying to keep the voltage around 0,6v signals from the narrowband lambda sensor.
The normal range of a lambda sensor is from 0.2V to 1.2V
what is normally happening?
Your car are using more gasoline per mileage.
your catalytic converter may not function that well.
Old 11-23-2006, 06:52 AM
Im just trying to figure out what will happen to my car if i put this chip in and the closed loop is disabled. Thank everyone.
Old 11-23-2006, 07:11 AM
Default Re: (motormike40)
Well, you have a burner? What program are you using? If you can get the program you can change that part of the bin file.
Old 11-23-2006, 07:23 AM
I have a friend who has everything, he said all I need to do it get whatever BIN I want and put it on my USB drive and he'll write and burn the chip for me. Im not too sure what he's using, perhaps Turboedit.
Old 11-23-2006, 08:04 AM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormike40 &raquo;</TD></TR><TR><TD CLASS="quote">I have a friend who has everything, he said all I need to do it get whatever BIN I want and put it on my USB drive and he'll write and burn the chip for me. Im not too sure what he's using, perhaps Turboedit. </TD></TR></TABLE>
Wow, another incredibly informative post from you. You need to do some more research on this stuff before you as these random questions......seriously. If I remember correctly (and I probably don't because I don't have an obd0 car) turboedit and bre are two of the most commonly used obd0 tuning programs. Do you even know if your car is obd0? You should read a bit more then after you have figured out exactly what you want to know ask the question while providing enough information for someone to give you a solid respose.
And if you are just needing a basemap to get to your tuner, then you should ask him for one or find someone who knows exactly what they are doing and have them make you one. You do not seem to have enough knowledge to ensure the safety of your engine while running this map. Just a suggestion.
Old 11-23-2006, 10:43 AM
Ok man clearly I said in this post, "I found one map, but it says the closed loop is disable. How will this affect my car?" Oh yea and by the way the car is OBDII converted to OBD I. This is a simple question needing a simple answer.
Old 11-23-2006, 11:52 AM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormike40 &raquo;</TD></TR><TR><TD CLASS="quote">Ok man clearly I said in this post, "I found one map, but it says the closed loop is disable. How will this affect my car?" Oh yea and by the way the car is OBDII converted to OBD I. This is a simple question needing a simple answer. </TD></TR></TABLE>
You could deduce the answer for yourself from the information given above if you chose to. I guess you want others to think for you.
Closed loop = the ECU looks to the 02 sensor to check the mixture and makes corrections based on that. Open loop = the ECU doesn't care what the 02 sensor is telling it and runs straight off the fuel table. IF you can't figure out how this affects your vehicle then you should pay a professional to set up your ECU, as you have no business messing with any of it (even though you claim that it is 'simple').
Old 11-23-2006, 12:15 PM
abnaasefmb's Avatar
go to this website and read http://www.pgmfi.org/
Old 11-24-2006, 03:11 AM
calvinPGMFI's Avatar
Default Re: What happens when my closed loop is disabled? (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">If i remember right. Closed loop is for cold start, then it goes into open loop once warmed up. So, if you live in a colder climate might be a pain. Not 100 percent sure thoguh.</TD></TR></TABLE>
wrong cold start closeloop is disable. Once warmed up the closelopp is enable and the car swtiches to openloop @ full throttle.
Calvin PMGFI
EG6 Love
09-17-2010 09:53 AM
jdm95
Engine Management and Tuning
02-02-2010 08:10 PM
didder
12-09-2008 06:58 PM
imbrzyant
12-30-2007 07:10 PM
mrx
03-06-2004 09:09 AM
Quick Reply: What happens when my closed loop is closed?
