3bar map + AEM EMS
Old 06-12-2003, 03:15 PM
R THIS's Avatar
Default 3bar map + AEM EMS
i have a quick question
does the GM 3 bar map sensor need to be calibrated into the AEM EMS??
my car ran perfectly with the stock map sensor, but as soon as i installed the 3 bar it wont even run. It starts fine but stalls after a second or two.
i disconected the vaccume line from the 3 bar map and it runs fine at idle... any ideas?
Old 06-12-2003, 03:26 PM
Hyper_Racer23's Avatar
Default Re: 3bar map + AEM EMS (R THIS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R THIS &raquo;</TD></TR><TR><TD CLASS="quote">i have a quick question
i disconected the vaccume line from the 3 bar map and it runs fine at idle... any ideas?</TD></TR></TABLE>
yes you need to change the map sensor voltage settings on the EMS.
Old 06-12-2003, 03:58 PM
R THIS's Avatar
Default Re: 3bar map + AEM EMS (Hyper_Racer23)
phew.. ok thanx... i goto the dyno tomorrow morning and i thought i just made a big problem by installing the 3 bar!! thanx
Old 06-12-2003, 03:59 PM
turbo Si's Avatar
Why do they even make you go through all the hassle? Why can't they be like other ecu's and be able to choose;
1 Bar
2 Bar
3 Bar
Old 06-12-2003, 04:01 PM
93LSivic's Avatar
Default Re: 3bar map + AEM EMS (turbo Si)
They do have that. You do however have to re-scale the maps to run your desired boost levels.
ekk41
10-24-2007 05:28 PM
Boosteddb8
06-12-2007 03:24 PM
turboeg77
02-26-2006 04:18 PM
Derek14
04-28-2004 09:18 AM
DD_JonnyLee
03-03-2003 03:37 PM
Quick Reply: 3bar map + AEM EMS
