acid dipping, how much weight can be saved?
Hi I plan on building my db7 for all motor. I want it light besides cutting it up. Anyone else weighed their sedans?
Re: acid dipping, how much weight can be saved?
I have a DB8 that I drag race, if you're wanting lightweight you have the wrong chassis. I have just come to terms that my car will always be heavier than the guy next to me. You can drop some weight by doing the normal weight reductions, but you'll never be as light as an EG or EK hatch.
I have not weighed mine, but I do plan on it here soon. Things I have removed or replaced to help save weight:
Carbon fiber hood
Up-pipe rather than a full exhaust
All hvac removed from under the dash
Sound deadening removed
Rear bumper support removed
J2 front lower control arms which are 6lbs lighter than oem
Smaller battery
Weld wheels in front, v2 skinnies in rear
Cut rear bumper
I still have full interior and a 10 point cage in the car.
Carbon fiber hood
Smaller battery
Cut rear bumper
200 lbs removed, you're still around 2500lbs without driver. As I said, it's the wrong chassis if you're wanting to be super competitive. If you are like me and just don't care and are ok with being at a disadvantage then go for it.
are you aware of how light people have made DC chassis?
I'm well aware of how light they have gotten them, are you aware that the DB's weigh 2765 from the factory? You can cut the car to hell and back and still weigh more than an EG chassis plain and simple. Trust me, I would love to shed weight out of my GSR sedan, but I refuse to hack it to hell and back in order to do so. Hell my setup in an EG is a 9 second car all day, in my Sedan I'll be estatic to see 10.5x lol.
I am not here to argue, but simply stating that the DB chassis is not the best option for drag racing unless you're doing it just to be different from everyone else that is all. Now if someone can point me to a DB chassis weighing around 2400lbs I would be more than glad to listen.
To the OP, acid dip your car and find out first hand how much weight can be saved. There aren't many of us DB chassis drag racers out there today.
im sure it wouldnt be too hard to get it to the low 2000's. people have dc's weigh much less than that.
tb's integra is 1900 with driver lol.
Guess it just depends on how much you want to hack the car up. I am aware of the weight, I am also aware of TB's car. I still know an EG stripped the same way will weigh less.
If the OP wants to build the 4dr then so be it, I know if I could do it all over I wouldn't have built mine. I would of built an EG hatch.
