acid dipping, how much weight can be saved?
Hi I plan on building my db7 for all motor. I want it light besides cutting it up. Anyone else weighed their sedans?
Re: acid dipping, how much weight can be saved?
I have a DB8 that I drag race, if you're wanting lightweight you have the wrong chassis. I have just come to terms that my car will always be heavier than the guy next to me. You can drop some weight by doing the normal weight reductions, but you'll never be as light as an EG or EK hatch.
I have not weighed mine, but I do plan on it here soon. Things I have removed or replaced to help save weight: Carbon fiber hood Up-pipe rather than a full exhaust All hvac removed from under the dash Sound deadening removed Rear bumper support removed J2 front lower control arms which are 6lbs lighter than oem Smaller battery Weld wheels in front, v2 skinnies in rear Cut rear bumper I still have full interior and a 10 point cage in the car. |
you can drop a lot of weight with removing all the undercoating misc brackets seam sealer I think it was like 200lbs
http://i1074.photobucket.com/albums/...5050C6FAAA.jpg |
There was 200lbs worth of undercoating and seam sealer on a DC chassis, or am I reading that wrong?
Originally Posted by 13173
(Post 49716729)
200 lbs removed, you're still around 2500lbs without driver. As I said, it's the wrong chassis if you're wanting to be super competitive. If you are like me and just don't care and are ok with being at a disadvantage then go for it.
Do you plan on racing in a class?
Originally Posted by ekcoupeh22
(Post 49716965)
Originally Posted by Danger
(Post 49717183)
are you racestatus on IG?
Originally Posted by guy_from_nerk
(Post 49716954)
I'm well aware of how light they have gotten them, are you aware that the DB's weigh 2765 from the factory? You can cut the car to hell and back and still weigh more than an EG chassis plain and simple. Trust me, I would love to shed weight out of my GSR sedan, but I refuse to hack it to hell and back in order to do so. Hell my setup in an EG is a 9 second car all day, in my Sedan I'll be estatic to see 10.5x lol.
I am not here to argue, but simply stating that the DB chassis is not the best option for drag racing unless you're doing it just to be different from everyone else that is all. Now if someone can point me to a DB chassis weighing around 2400lbs I would be more than glad to listen. To the OP, acid dip your car and find out first hand how much weight can be saved. There aren't many of us DB chassis drag racers out there today. |
(Post 49718872)
I am not here to argue, but simply stating that the DB chassis is not the best option for drag racing unless you're doing it just to be different from everyone else that is all. Now if someone can point me to a DB chassis weighing around 2400lbs I would be more than glad to listen. To the OP, acid dip your car and find out first hand how much weight can be saved. There aren't many of us DB chassis drag racers out there today. im sure it wouldnt be too hard to get it to the low 2000's. people have dc's weigh much less than that. tb's integra is 1900 with driver lol. |
Isnt acid dipping just to remove rust and clean up the metal for paint/resto prep?
thats what i thought, im sure itll shed some weight but probably not too much
(Post 49718872)
Guess it just depends on how much you want to hack the car up. I am aware of the weight, I am also aware of TB's car. I still know an EG stripped the same way will weigh less.
If the OP wants to build the 4dr then so be it, I know if I could do it all over I wouldn't have built mine. I would of built an EG hatch. |
(Post 49721374)
