Does it make a difference how long ground wire is ?
Old 10-30-2004, 11:46 AM
Kavehman's Avatar
Default Does it make a difference how long ground wire is ?
I want to locate my amp somewhere else in my car, I am wondering if it makes a difference if my ground wire is longer than the one provided originally by the wiring kit
If it does, ideally how long should my ground wire be ?
Old 10-30-2004, 12:33 PM
Kyles ej1's Avatar
Default Re: Does it make a difference how long ground wire is ? (Kavehman)
the only difference it will make is if its not long enough your amp wont turn on
Old 10-30-2004, 01:24 PM
EBP_SI's Avatar
Default Re: Does it make a difference how long ground wire is ? (egcoupe)
ideally you'd like to keep all the wiring as short as possible. where did you plan on mounting your amp that doesnt have a possible ground spot close by?
Old 10-30-2004, 01:25 PM
D'Ecosse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman &raquo;</TD></TR><TR><TD CLASS="quote">...If it does, ideally how long should my ground wire be ?</TD></TR></TABLE>
It <U>does</U> make a difference- you can get as much voltage drop across the ground wire as you can on the positive supply.
Relocating your sub shouldn't be an issue though - wherever it goes, you want to make the ground wire as short as possible (say ~ 18") and ensure you have a good solid connection to the chassis. Make sure you clean any paint off your ground point with some emery cloth and use a star washer to get good "bite" between the terminal & chassis. Bolt it solidly to the body with bolts, lock washers & nuts - no puny sheet metal screws!
Best thing is to use a proper grounding terminal, like one from stinger or whoever takes your fancy. The wire gauge for the ground should be at least the same as that for the power.
Old 10-30-2004, 05:44 PM
Kavehman's Avatar
thanks for all the advice guys, I had the amp mounted on the back of my box, i moved it so its sitting in a more vented area, i had to lengthen ground wire byabout 3 inches for it to fit, so i dont think i have affected it that much.
Thanks a lot
MilanoCivic97
Audio / Security / Video
04-04-2007 11:22 AM
Jer'rome
06-26-2006 01:59 PM
hondaracing1
07-23-2004 08:13 PM
J^M^
08-08-2003 11:25 PM
garyyam
10-22-2002 04:05 PM
Quick Reply: Does it make a difference how long ground wire is ?
