Roller rocker clearance issue
Old 04-26-2016, 04:52 AM
Duncann's Avatar
Default Roller rocker clearance issue
I got my hands on a like new ferrea roller rockers(singleroller) with turbo/curcuit cams but the only issue is the width for the rocker arm assembly is 2.107.5
My rockers measure
2.103
2.104
2.105
2.094
2.095
2.103
2.107
And.... 2.113
Doesn't fit in my head :s
Figured many someone's ran into this issue and had to shave some material off the head as I assume it wouldn't have to be a machined because it's the rocker assembly but kinsa worried about the unevenness that could wear the side of the rocker arm from rubbing at high rpm
Any suggestions would be really appreciated,
currently running behind in my build due to bad luck, like installing the rockers then the last one didn't fit, installed arp main studs, last one pulled the threads out in the block out-.- gotta helicoil the bottom end, awesomeeeee :')
Old 04-26-2016, 05:30 PM
PSI GUY's Avatar
Default Re: Roller rocker clearance issue
My rockers measure
2.103
2.104
2.105
2.094
2.095
2.103
2.107
And.... 2.113
The rockers are pressed onto the pin that the bearing rolls on. Can you pivot them at all or are they solid?
Jabuuty671
02-17-2012 05:21 PM
balliso911
07-09-2010 12:03 PM
rmcdaniels
10-26-2005 12:57 PM
h22powered
12-10-2003 05:59 PM
dc2monkie
09-24-2003 04:31 PM
Quick Reply: Roller rocker clearance issue
