Replacing valve springs and seats with new springs?
Old 04-24-2005, 06:51 PM
Takumi Fujiwara's Avatar
Default Replacing valve springs and seats with new springs?
I don't have the head apart from the block too often. I'll be replacing my valve springs in my head. Should I also replace the seats & retainers while I'm at it?
It's an R head, and will be replaced with OEM parts. What do I look for, or rather, how do I know if a retainer or seat should be replaced? Is there a service thickness or something?
Old 04-25-2005, 09:17 PM
DOHCsideracing's Avatar
Default Re: Replacing valve springs and seats with new springs? (Takumi Fujiwara)
Just from my own experience on the 2 B18c1's I had apart. Both looked pretty good on all of the head stuff EXCEPT the valve guides and seals, and the seals might have been OK, but the guides had a fair amount of play in them, and the seals get f'ed when you take out the guides.
The FSM test is stick them out 10mm fromt he seat, and measure the lateral (side-to-side) movement. It should be less then .006", with a service limit of .009" (??).
Mine were like .030", which couldn't have been a good thing. Motors had a lot of high rpm miles on them (one with 100k and the other with 170k), so yours might still be pristine.
I wouldn't worry about the seats, unless they look worn (which I seriously doubt), since they really don't have any load, or stress, other than the very slight rocking from the compressing spring.
As far as the retainers go, I wouldn't mess with them, unless you plan on upping the redline. Foctory ones are plenty reliable. Went 200k with the same ones (from the 170k motor).
My 2 cents...
Adrian
Old 04-25-2005, 11:35 PM
GOLDBERG's Avatar
Default Re: Replacing valve springs and seats with new springs? (DOHCsideracing)
how do you remove the valve guides anyhow?
Old 04-27-2005, 07:26 PM
Default Re: Replacing valve springs and seats with new springs? (GOLDBERG)
thx for the information. Mine is marked as a 98, so I'll most likely reuse most of it and just check the guides. thanks. You saved me money on stuff I probably don't need to buy.
Old 04-29-2005, 10:34 PM
Sorry for the delay, been tied up with an engine build. Yeah!!!
To change the valve guides, I think it would be best taken to a machine shop, but the FSM says you can do it with an air chisel, with a custom attachement, or if you have all day, you can use a regular hammer...
Look here:http://www.redpepperracing.com...b/abl. You can scroll to the previous and next pages to get more info...
To install them they say you need to heat the head to something like 300°, and freeze the guides to get them in. I think it only cost around $60 to get the guides replaced... but I'll be getting it done here next week so if I'm way off, I might be telling you how hard it was with a hammer...
Old 04-29-2005, 10:41 PM
b19coupe's Avatar
Changing guides is no walk in the park, trust me. Heat the head to 300 degrees F. (not as easy as it sounds), then use the special valve guide driver and smack the guide down (towards the combustion chamber) to break off any carbon. Once the guide is loose, drive it out the top (towards the spring side of the head). You have to be very careful when installing the new guides, or you can get them cocked. Just ask Tom at Portflow, he checked a head for me after I changed the guides
Old 04-29-2005, 10:50 PM
Default Re: (b19coupe)
I'll take that as word of wisdom...
carlos8
11-25-2015 09:17 PM
sleepencivic
08-15-2011 02:34 PM
jyacoba2009
18
09-29-2009 05:41 PM
sewelh2
05-12-2007 02:09 PM
shingles
05-15-2005 09:49 AM
Quick Reply: Replacing valve springs and seats with new springs?
