B20 Vtec Timing
B20 Vtec Timing
Hey guys,
Just finished timing my b20 vtec with a b16 head. I'm using a b20 water pump and timing belt and adjustabe cam gears.
I put the the bottom end to tdc and lined the cams up as well, but when i put the belt round the cam gears it lines up tooth to tooth, so I loosened the gears and turn so it lines up with the belt, now I havent change the actual cam position. Just shows that the cams are now advanced, is this normal?
Thanks
Nath
Thanks
Nath
Re: B20 Vtec Timing
use a b16 timing belt it will make up the difference i did the same with one fo my builds how ever i used a ls watter pump i think its the same eitherway
adamlightweight
11-15-2017 08:41 AM
jdmh22eg2
10-23-2010 07:31 AM
Fook_me_honda
03-27-2010 11:54 AM
1SickHb
10-04-2005 09:00 AM
