Can i use stock valves???
Old 09-18-2004, 03:59 PM
LsBack's Avatar
Default Can i use stock valves with....
I am planning on putting a Ls head together with Crower 404's and Crower Valvesprings and retainers but i was wondering can i use stock valves or should i just upgrade to aftermarket valves.
Modified by LsBack at 1:21 AM 9/19/2004
Old 09-18-2004, 04:42 PM
EKhatch's Avatar
Default Re: Can i use stock valves with.... (LsBack)
Stock valves will be fine as long as they are in good shape. I would at least get a valve job done though. Aftermarket valves can net more power but the difference would be minimal. It's all in the valve job.
Old 09-19-2004, 10:34 AM
LsBack's Avatar
Default Re: Can i use stock valves with.... (EKhatch)
THanks
Old 09-19-2004, 11:25 AM
boosted k20's Avatar
yea no need to replace ur valves. i just installed CROWER 403 cams in my car with crowe valve springs and retainers. no need for new valves
Old 09-19-2004, 01:04 PM
Swollen Member
SicNA94TegGsR's Avatar
Default Re: Can i use stock valves with.... (boosted k20)
what about the fact of the valves now traveling farther with the new lift of the cam. I have heard that the stockers get polished in the area of the valve seals where they traveled before, and the could possible leak after that.
turboman2.2
07-04-2010 10:08 AM
slowtegkauai
04-12-2008 01:37 PM
dand39
02-16-2005 11:47 PM
turbo sol
12-17-2004 01:28 PM
Smoothy
09-23-2001 05:38 PM
Quick Reply: Can i use stock valves???
