revving up and down
revving up and down
what can this be ?? my girlfriend starts her car it'll be fine for 20-45 seconds then the rpm would just go up and down i know its a typical problem for honda's but how can i fix this?? Is it a o2 sensor or w.e.??
base model 02 rsx
base model 02 rsx
Re: revving up and down
Sounds like a vacuum leak. When you get idle surges like that it's the first thing I would check. Then I would try cleaning out your IACV because they tend to build up with carbon and oil and the stick.
would you know where all that is?? can you help me find pics if you dont mind?
The IAC valve is located by the Throttle Body.
Pick up a Helms manual from your local auto parts store. There should be a walk-through on how to conduct a vacuum leak test.
This ^ Same issue mine used to have, a quick removal of this and good cleaning should do it. Watch the retaining screws my friend has some strip on him before, prob a good idea to take the whole throttle body off and pb blaster them. You can get more leverage on them with the tb off.
