First time starting car... Few problems *searched*
Old 04-19-2010, 08:19 PM
Hurleystrcr9621's Avatar
Default First time starting car... Few problems *searched*
Ok so first of all thank you in advance for any help you may be able to offer. Car in question is a 1996 Honda Integra Type R imported from Japan. Bought the shell and swapped in a B18C ITR engine, bought through hmotorsonline. Anyways, started it up for the first time tonight, car has check engine light and overheating light (WTF?) on and won't rev past ~2600 rpm roughly. My friend thinks it's an o2 sensor. Will buy new in morning, just wanted input. Also, there is a vacuum hose right on top of the throttle body that I cannot find a mate for. Any ideas where this goes? It is right on top of the throttle body facing the intake. I have no idea. Thanks all!
Old 04-20-2010, 06:43 PM
Default Re: First time starting car... Few problems *searched*
Now I am showing codes 3,7 and 14. Any help guys? Thanks!
Old 04-20-2010, 06:49 PM
nsxter's Avatar
might help if you fix codes 3,7 and 14 smart guy
Old 04-20-2010, 07:10 PM
Dave-ROR's Avatar
Do you mean the cat heat up light? Or is the temp gauge at H? The "overheating" like may just be the cat warming/heat circuit. We don't have those lights on USDM cars so I'm not sure if that goes away when it gets warmed up or if it's telling you there's a problem.
Old 04-20-2010, 07:13 PM
Dave-ROR's Avatar
How in the world is that post going to help him? At least tell him what they are.
FWIW, assuming that ECU returns the same codes as the USDM car does:
3 = Map sensor
7 = TPS (throttle position sensor)
14 = IAC valve.
Now for 3 and 7, the plugs are the same and inches apart, you likely just have them reversed. Swap the plugs and see if that goes away (may have to reset the ecu).
Does the JDM motor have an idle air control system? What ECU are you using?
Old 04-20-2010, 07:15 PM
Dave-ROR's Avatar
Oh yeah, post a pic of the vacuum hose you are talking about, and related hoses (where it starts, anything tee'd to it, etc)
Old 04-20-2010, 07:23 PM
Dave, thank you so much. I knew that code 3, 7 and 14 were all the sensors, but I didn't know if all three of them were the luck of the draw with this swap or maybe a sign of a bad ecu. Thank you all for the info, will take a multi-meter to it tomorrow.
Old 04-20-2010, 07:24 PM
p73 ecu btw
Old 04-20-2010, 07:27 PM
Dave-ROR's Avatar
Before bothering with the multi meter, just swap the TPS and MAP plugs. I've done so before and had issues, until I noticed the VAFC showing completely inaccurate throttle %, then remembering that I had both unplugged earlier.. swapped the plugs and all was well again.
By P73 do you mean a USDM ECU? I'm certainly not an expert on this subject, but I'm pretty sure the JDM motor is misssing sensors and such that the USDM ECU checks for, one may be the IAC. Again, not sure.. find the guys here who know the JDM cars/motors and check in the Hybrid forum.
Old 04-20-2010, 07:29 PM
Will do, thank you. It should be the jdm p73 ITR ecu, it came as a motor/trans/ecu package from hmotors
Old 04-20-2010, 07:32 PM
Dave-ROR's Avatar
Gotcha.
It's unlikely that the engine would arrive with 3 bad sensors (or so I'd hope, I've never had that many bad sensors on swaps before). Hopefully the two plugs are just reversed, which just leaves you with the IAC to troubleshoot. If you need the pages relevant to IAC testing from the service manual let me know. I'd assume they are the same for the JDM and USDM motors so they should be fairly accurate. I can take pics of the pages from a 98 service manual if needed.
Old 04-27-2010, 10:17 AM
22's and Man Boobs's Avatar
Put a chevy tree-fiddy in that somnabitch. It's a direct bolt in swap, except it uses a modified VTECH solenoid that splits the VTECH to allow both heads to VTECH. ****'s hella fresh.
Reason it's throwing codes is simple. The codes are 3, 7, and 14
3+7+14=24
24/3(the number of codes it's throwin)=8
It's begging you to V8 swap the **** out of it!!!
Old 04-27-2010, 11:25 AM
Dave-ROR's Avatar
Wow that post was retarded.
Old 04-27-2010, 11:39 AM
IanBlake's Avatar
people like you should not be here, not helping in anyway troll
Old 04-27-2010, 12:54 PM
nsxter's Avatar
there is a thread devoted to check engine codes you dumb ***
Old 04-27-2010, 01:02 PM
Dr. DC2's Avatar
wish i had a Honda ITR... good luck getting this baby going! post some pics!
Old 04-27-2010, 01:37 PM
IanBlake's Avatar
bla! bla bla!
not helping retard
Old 04-27-2010, 05:20 PM
nsxter's Avatar
bla! bla bla!
not helping retard
nice to show us a pic off your mom
Old 04-27-2010, 05:25 PM
Dr. DC2's Avatar
really mom jokes?
Old 04-27-2010, 07:45 PM
srt4mike's Avatar
Old 04-28-2010, 07:47 AM
Dr. DC2's Avatar
ROR!!! Thats awesome Mike!
Old 05-04-2010, 06:31 PM
Anyways... here's an update. MAP and IACV were easy fixes. That left the TPS. Replaced the TPS today, still throwing TPS code. It will rev all the way to redline, but VTEC does not engage.
Last edited by Hurleystrcr9621; 05-04-2010 at 06:56 PM. Reason: I was having a bad day, no sense in flaming or making myself look bad.
Old 05-04-2010, 06:49 PM
nsxter's Avatar
Holy **** lol. Some people are douchebags. Anyways... here's an update. MAP and IACV were easy fixes. That left the TPS. Replaced the TPS today, still throwing TPS code. It will rev all the way to redline, but VTEC does not engage.
here i will help you this time the tps sensor needs to be calibrated and you need to reset the ecu
Old 05-04-2010, 06:55 PM
Thank you, was told by a tech at Acura that it would not throw a code if it was just calibration... I thought that was weird because if it was not seeing the right voltage... CEL. Thanks for the assurance
chicklet
04-21-2016 05:01 PM
ReillyEK
31
06-06-2013 08:20 AM
BlkTegi
11-28-2008 10:55 AM
mrDalvin
02-01-2007 07:30 AM
kaneda3
11-17-2006 12:12 AM
Quick Reply: First time starting car... Few problems *searched*
