Very weird noise coming from intake
So it's a b20b motor with a ls intake. The swap was just recently done but when the car starts or idles or even sometimes moving it sounds like a geese is stuck in the intake manifold I mean it's loud.
It's not the regular after market intake sound either. Not even a tuner shop heard of it before.
It sound like a starter is going off basically, but it's not the starter. And it gets even weirder I will pull the intake out and block the air flow to the engine with my hand and it doesn't shut off.
The noise sometimes gets to a point where it's louder than my car and I have a 3inch straight pipe.
Any solutions or suggestions would be great.
Re: Very weird noise coming from intake
well if the sounds gone with a diffrent intake then ditch the intake, you say its a ls intake but is a after market intake? and i doubt a intake will cause a loud noise you describe, might be a drive belt to axles, try diognosing it a lil more than just saying its a loud noise, have you removed the power steasring belt and AC belt to rule out those belts? does the sound get louder as the engine revs higher? thats would point to something internal or trans related.
mikzsan
Acura TSX
07-15-2018 01:43 PM
DSBP1
18
07-07-2007 07:51 PM
Puffwheat
02-13-2004 09:59 PM
