Sunroof has the jitters
Old 08-21-2002, 08:27 AM
Tegra's Avatar
Default Sunroof has the jitters
Yes, I have used search, but I couldn't find what I needed. My sunroof shakes when I open it, but not when it closes. I used almost a whole tube of lithium grease on the tracks, but to no avail. I ran it back and forth numerous times, with no change in operation. I was wondering what to do. When you guys grease the tracks, do you actually detach the sunroof from the car, or just open it? What else could it be?
95 Integra LS 2door
Old 08-21-2002, 08:55 AM
hybridDC4's Avatar
Default Re: Sunroof has the jitters (grivoid)
mine does it too bro...its from prolonged driving at high speeeds with it open....i think every integra in the country suffers from it or will the wind scoops under it and throws it off track
Old 08-21-2002, 09:02 AM
2lowintegra's Avatar
Default Re: Sunroof has the jitters (hybridb20turbo)
i HAD the same problem.... put a little oil in there, open/close a few times and it should run smooth again, mine did!!
Old 08-21-2002, 09:10 AM
New User
gsr squirrel's Avatar
Default Re: Sunroof has the jitters (toolowintegra)
motor oil?
Old 08-21-2002, 09:11 AM
joejohnson's Avatar
Default Re: Sunroof has the jitters (gsr squirrel)
I use WD-40. Just spray it along both rails and you'll see a night and day difference!!!
Old 08-21-2002, 09:31 AM
BSQ
BSQ's Avatar
Default Re: Sunroof has the jitters (joejohnson)
I initially lubed the sunroof tracks with WD-40 to loosen the oil dried up grease. I opened and closed the sunroof several times. Then I took a rag and cleaned the tracks. Once the tracks were cleaned I applied silicion grease to the tracks and opened and closed the sunroof several times to distributed the grease evenly. The sunroof has worked like a champ ever since .
Old 08-21-2002, 10:04 AM
Default Re: Sunroof has the jitters (BSQ)
yep, motor oil is what i used....just a bit.....and it worked great...
though any of these would be good, i was gonna use silicon too but i didn't have any laying around the house
Old 08-21-2002, 11:58 AM
miketegra's Avatar
This is a well-known problem - in fact, there is a TSB about it.
I lucked out and got the dealership to fix it under warranty a few years back.
If the grease (or oil) does not work, then you will need to replace the sliders and brackets - not cheap or easy..oh well, thanks Honda.
Good luck amigo....
Old 08-21-2002, 01:33 PM
GSRaCeRbOI's Avatar
this is the exact thing I do.. I use the WD-40 to clean off the existing dirty and grease.. then wipe it clean w/ a rag and apply some grease (I used white lithium grease) and then opened and closed it a few times and it has been very smooth... reason I got so damn annoyed w/ it is because my alarm has a sunroof closure module.. when the sunroof was slow or lagged or got stuck prematurely the module would think the sunroof was closed when it wasnt..
unless you didn't mention it.. maybe you didn't clean the tracks of the dirt and grime built up before using the whole tube of white lithuim grease.. see if that helps...
Old 08-21-2002, 03:09 PM
Rory Breaker's Avatar
Default Re: Sunroof has the jitters (GSRaCeRbOI)
Did the same thing and mine has been kickin strong for a while now.
Wiped the rails clean and covered them in lithium grease, BOTH in front and behind the sunroof glass. Open it and close it, then open it and reapply, open/close/open, reapply and youre set.
portugueboy10
05-10-2014 11:06 PM
ritz7
14
07-30-2008 01:25 PM
g2turbo
04-23-2007 08:44 AM
Mr_Moos
03-06-2005 09:01 PM
Quick Reply: Sunroof has the jitters
