sunroof issue.
sunroof issue.
I have a 95 ex and for some reason my sunroof doesn't go up by itself anymore.
I have to push the button and push it up for it to go in "tilt" mode.It still slides back and closes fine though. Nothing out of the normal happened today that would cause this problem to start.Any help would be appreciated.Thanks.
Re: sunroof issue. (ritz7)
to be honest im not really sure but on my crx it used to get hung up on a little peice of the track that was nicked...just run your fingers across the track and see if you feel any little imperfections on the track
Try some silicone lube or some grease, see how that works for u, will help if that tracks and the pulley system is dry,but not so much if the track is bent
Re: sunroof issue. (jtmoney2002)
I will give the silicone thing a try.The thing that confuses me though its only when it goes in the tilt mode.Once its fully tilted up it slides back no problems.But ill check it out later on too see if it still does it or not.
yea i sprayed wd40 on mine and when it didnt work i realized it was a little peice of metal (i mean little, could only feel it not really see it)...good call tho
My 95 EX has the exact same problem: it gets stuck when I push the tilt button (thus necessitating me to push it up with my hand) but it opens just fine when I press the slide button.
I WD40'd the crap out of it and that just made it slide a lot smoother...it still sticks when it opens. I have the feeling that the opening motor might be dying. How many miles on your car? Mine has 236k
Use lithium grease! I too have a '95 Ex w/ sunroof and have loads of fun getting the thing to close all the way, to fully tilt, or sometimes it stops mid-track.
maybe they just get old. i have to push it up while pushing the button. it opens fine but to close it i have to push it up or it will; rub the roof scratching it
anyone know how to fix them seems like everyone gets problems with the sunroof
miamirice
03-24-2013 04:52 PM
Markus
22
06-25-2003 08:28 AM
