gsr build clutch question
Old 03-29-2011, 06:17 PM
OrangeTeggy's Avatar
Default gsr build clutch question
My build
11:5 to 1 Compression Je Pistions 81.5mm bore
Eagle rods
stock crank
blox type b cams, springs retainers tb.
Also will be spraying a 75 shot at the track
This car will be used as a daily driver/ tracked once a month
I was told an oem exedy clutch with a 7.5 lbs fidanaza flywheel will work. And I also have been told it will not work
Just looking for some input ..
Old 03-30-2011, 06:11 PM
alteredimages's Avatar
Default Re: gsr build clutch question
it will work but will not last as long as normal. best bet is to go with a mild aftermarket like a street strip disc or a dual friction style. i have had the centerforce dual friction on the bottle b4 and worked well and was good price right now i have a act 4 puck sprung hub with a xtd street light 11 lbd flywheel in my gsr and it works great and engagement is not to harsh at all.. hope this was so,e help for you
jacoblytle
Transmission & Drivetrain
02-02-2015 08:08 PM
jetspeedz
09-08-2009 08:24 PM
Vroinshk06
10-16-2005 08:29 PM
AirWaveGT
05-18-2004 11:05 AM
hybridreams
12-14-2003 08:35 AM
Quick Reply: gsr build clutch question
