Clutch and Flywheel combo setup for Gsr 400hp range
Old 09-06-2009, 12:48 PM
jetspeedz's Avatar
Default Clutch and Flywheel combo setup for Gsr 400hp range
Ive been reading through lots of threads and im down to a Exedy flywheel b/c its steel and i think that is safer then aluminum F1 and others.
As for the clutch im a little torn b/c there are so many i want one that has the oem feel b/c ill never be taking it to the strip and its a daily driver that will never be abused but i don't want any slip in case im hitting 20psi boost and it will be close to 400-450hp i suspect after tune on built gsr motor.
1. Exedy Stage II
2. Clutchmasters FX400
3.stage 3 Comp Clutch
Which do you guys recommend and have had the most success with.
Thanks
Old 09-06-2009, 01:23 PM
Man U FTW
Schister66's Avatar
Default Re: Clutch and Flywheel combo setup for Gsr 400hp range
I have Comp. Stage 4 and like it. I daily my GSR and dont mind the clutch pressure or the engagement of it...
Old 09-06-2009, 01:24 PM
th3pwn3r's Avatar
Since it's never going to be abused I'm sure a stock clutch will work just fine. I'd classify a high rev launch as abuse. If you're just easing into the throttle and not abusing it stock will work just fine.
Old 09-06-2009, 01:26 PM
brian...'s Avatar
What's the point if you aren't gonna drive it hard?
And no the stock clutch won't hold up to that kind of torque.
Old 09-06-2009, 01:29 PM
th3pwn3r's Avatar
1. Exedy Stage II
Thanks
By the way...do you think this engine is going to produce 400-450hp at idle? I'm pretty sure you'll have to hammer on the gas a bit to create that kind of power, some people might classify that as abuse but it's all opinion.
Old 09-06-2009, 03:46 PM
jetspeedz's Avatar
I want it to have a oem feel for daily driving and if i get on the gas not to slip.
Old 09-06-2009, 03:54 PM
b20beast83's Avatar
clutches are rated in tq capacity
Old 09-06-2009, 04:01 PM
jetspeedz's Avatar
correct good point... Now what do you suggest
Old 09-08-2009, 08:24 PM
inspector01's Avatar
Same clutch im running and my wife has driven it bare footed and not complained so it is very easy to drive/light pressure.
IgnitionZ055
11-04-2008 06:06 AM
EtchaSketch
05-13-2006 02:01 PM
blackjdmEKcivic
11-24-2004 07:21 AM
Nightscape
05-17-2004 01:17 AM
98DC2
07-31-2002 07:11 AM
Quick Reply: Clutch and Flywheel combo setup for Gsr 400hp range
