HELP QUICK!! Question about trans fluid fill :(
i cant get the damn bolt loose on the fill plug on the transaxle and i already ****** drained it! the idiot before me put gear oil in the trans and i had to change it out cause its been shifting like ****! my question is, is there any other way to fill the manual trans? thanks
Re: HELP QUICK!! Question about trans fluid fill :( (InjectedSS)
An alternative would be to remove the VSS (vehicle speed sensor) from the tranny (screws in) and fill it up there. I know a lot of people who use this method. Some believe it easier than messing with that top fill bolt.
good luck.
good luck.
just get a breaker bar or a pipe extension for your existing ratchet for more leverage.... that should get it loose...
Re: HELP QUICK!! Question about trans fluid fill :( (hondamanwill)
I just did mine on Saturday- sprayed PB blaster onto the bolts and let it sit... then had to use a 1/2 inch ratchet to bust the top one loose. It's friggin tight.
Re: HELP QUICK!! Question about trans fluid fill :( (Rtzx9r)
Wait. Hold on. You can't get the drain plug loose, yet you already drained it? That doesn't make sense to me. You need a 3/8 drive socket wrench and a pump to get the fluid in. Put the socket wrench box on the drain plug (no socket, the bare box end will take care of it) and loosen. Then get a pump from checker or somewhere, and pump the oil into the tranny. VSS is a pain to get to, but can work if you don't have a pump. Then tighten up, no need to make it dificult.
Re: HELP QUICK!! Question about trans fluid fill :( (Midori Shinkansen)
huh? no dude i cant get the FILL plug loose well i think i got it filled, i took that panel off that has like 8 bolts on it and then it pops off, well i took that off and got a transmission drain plug kit and basically drilled a hole in that plate, then used the drain plug kit to basically cover the hole and now i have a new fill plug i just filled it to the book specs and called it good thanks guys
Did you maintain the same height for the new fill hole? You CAN overfill the tranny... which is not good.
Re3irth
12
09-01-2004 02:58 PM
