help!!! code 73
Re: help!!! code 73 (boostedteg)
I like your post trailer, f-nascar, f-civics, and f-n\a. anyways, on my 12psi gsr I am constently geting 71,72,73,+74 codes wich are missfire codes. try these options is this order: decrese the plug gap, change the plugs out for some ngk non-projected nose copper plugs(heat range 7), slightly advance timing(trust me), buy a msd 6a, or if all else fails sell the car.
Re: help!!! code 73 (grndcont)
yeah i bought the ngk brpes somthing. are those the ones to get. i gt a 73 constatnly. and at times the engine light flases instead of staying on.
Re: help!!! code 73 (Drag III Integra)
u are actually leaning bro...try richen up the fuel a little bit or invest on some fuel pump...i used to have the same problem with greddy kit and all i did is put som fuel pump and the random misfire never came back...random misfire can be anything an dit can be something serious too..so pay close attention to this matter.
Re: help!!! code 73 (smkngsr)
does is gives you the CEL at idle, vacuum or what ?
I had all 4 cylinders misfires before at idle, and it turns out that the FMU was bad, it stick open dumping too much fuel at idle...
check your plug gap, and for once, reset the battery, bypass the fmu and leave it on idle and see if it still bogged...
stan
stan
