is it hard to change an integra moon roof?
Old 12-27-2004, 06:20 PM
ginlv888's Avatar
Default is it hard to change an integra moon roof?
well basiclly i was driving on the highway and my moon roof flew off and the rubber molding ripped.i could not find just the molding so i got a used moon roof.i just wanted to see if anyone knew if it would be hard to swap them?
Old 12-27-2004, 06:37 PM
miketegra's Avatar
Default Re: is it hard to change an integra moon roof? (ginlv888)
Since you didnt say what year car it is, nor if the moonroof is powered or not, its kinda hard to say. I know the hacks at the stealership had to take out the headliner in my 94 GSR to fix the power moonroof (under warrantly) so that should give you an idea of the work involved....meaning...its easy, but time-consuming since one is dealing with interior parts and such (lotsa screws, gotta be careful not to scratch anything, etc.)
With a little more info, we can probably help you out some more.
Modified by miketegra at 1:07 AM 12/28/2004
Old 12-27-2004, 07:54 PM
skunk2eg's Avatar
Default Re: is it hard to change an integra moon roof? (miketegra)
i had a similar problem and they put a new one in for $100 labor
Old 12-29-2004, 10:04 AM
ginlv888's Avatar
ya sorry its a 97 integra power moonroof .i just know if i do it myself it will probably take a while.but my car has no warranty anymore so i dont think i want to pay them to do it at a dealership.
Old 12-29-2004, 10:09 AM
PatrickGSR94's Avatar
Damn, the same thing happened to my friend's Mazda 626. Sure hope it doesn't happen to me.
But when I had my headliner out a few weeks ago to fix a water leak, it looked like the whole sunroof assembly would drop out quite easily after removing the nuts/bolts.
Old 12-29-2004, 12:57 PM
sabotage7's Avatar
same thing happened to me...i went to the salvage yard and bought a new piece of glass along w/the rest of the roof for $100.....it was pretty easy....i installed it myself, took about 40 mins after i figured out what i had to do.
Old 12-29-2004, 01:23 PM
integ6657's Avatar
Default Re: is it hard to change an integra moon roof? (sabotage7)
There isn't a whole lot to changing them out if it's just the glass. There are covers on each side of the glass with screws underneath {4 I think} Just raise the roof just a tad so as to relieve pressure and to enable yourself to get to the bolts. Be sure to count the shims and notice their alignment when removing the bolts so that you can put them back. Good luck
Old 12-30-2004, 04:32 PM
ginlv888's Avatar
ok thanks for the info im gonna try to put the new moonroof in myself.
Old 01-11-2005, 11:52 AM
ginlv888's Avatar
ok i replaced the moon roof by myself.it wasnt to hard... good info from integ6657.but it was a bitch getting those damn bolts out.thanks
Old 01-11-2005, 12:25 PM
integ6657's Avatar
No problem. Changed quite a few at the Old dealership. Glad I could help.
crower
03-22-2016 09:56 AM
BlueStar
Acura TSX
48
09-15-2009 05:15 PM
vtek9
10-04-2007 03:45 PM
Brasspremier
12-09-2002 09:49 PM
Quick Reply: is it hard to change an integra moon roof?
