GSR Starts really bad now after replacing fuel line from filter to fuel rail, advice?
Old 05-02-2010, 09:29 AM
OH_1fstgsr's Avatar
Default GSR Starts really bad now after replacing fuel line from filter to fuel rail, advice?
Car starts very badly now. It have to prime the fuel twice before I turn the key. So I did a little test, checked the fuel cap. Is there still pressure, yes. Why, check valves. No issues back at the tank.
New idea maybe air is getting into the new hose or fittings.
Gas milage is way worse after the change. Half tank 100 miles, normal is 150 miles. Nearly two gallons evaporated.
I have double check all the fittings, torque settings and for leaks, nothing.
Tonight I'm going to remove the hose and see how much fuel is actually in it. My guess after sitting for 6-7 hours not much.
Anyone else ever have a issue like this?
Old 05-02-2010, 10:54 AM
WDG_729_ITR's Avatar
Default Re: GSR Starts really bad now after replacing fuel line from filter to fuel rail, adv
Did you remove the whole fuel rail whenever you replaced the fuel line?
Old 05-02-2010, 10:55 AM
OH_1fstgsr's Avatar
Replaced fuel line from the filter to the Stock fuel rail. I did not remove the fuel rail.
Old 05-02-2010, 11:00 AM
Ok...I wasn't sure if maybe you removed the fuel rail to do that and knocked an injector out of place. Do you think it might be the fuel pressure regulator?
Old 05-02-2010, 12:05 PM
OH_1fstgsr's Avatar
Don't think so, didn't even touch it. Unless it got clogged by something that was in the new hose. I will take a look when I remove the hose tonight.
Old 05-02-2010, 12:39 PM
94VTEC2TONE's Avatar
did u put in new copper washers?
Old 05-02-2010, 02:55 PM
OH_1fstgsr's Avatar
New OEM washers, double checked them against the copper ones that came with the hose. Same size.
Old 05-02-2010, 05:47 PM
best bet is to get a fuel pressure tester man see if u got fluctuation or something. what kinda line did u put in
Old 05-03-2010, 03:20 AM
OH_1fstgsr's Avatar
I have order another aftermarket replacement hose. The one I used was a B&R. Didn't have time on Sunday to take it apart again yet. Will do it tonight, no other plans.
Old 05-03-2010, 03:11 PM
OH_1fstgsr's Avatar
I removed the hose. I had NO fuel in the fuel rail. All gone, just as I suspected.
It some how all evaporated. Holes in the hose or gaps around the fittings that are letting air in but not letting fuel out. Now I'm waiting on the replacement hose from Jegs.
Old 05-03-2010, 03:17 PM
mouab18c1's Avatar
Hmm faulty product.
Old 05-03-2010, 03:27 PM
OH_1fstgsr's Avatar
Originally Posted by mouab18c1
Hmm faulty product.
MAYBE.
Once I place on the new one and have no issues. I think that would be a fair assumption.
c95gsr
10-09-2009 08:50 AM
DevontElan
02-14-2008 03:16 PM
EFin' Kyle
04-27-2006 11:43 PM
EK FLY
01-06-2006 05:04 PM
Quick Reply: GSR Starts really bad now after replacing fuel line from filter to fuel rail, advice?
