fuel rail stud broke
Old 01-02-2002, 08:41 PM
New User
Brian_92GSR's Avatar
Default fuel rail stud broke
When I was installing new injectos a while back one of the studs holding the fuel rail to the intake manifold broke off. Does anyone know if these studs are screwed in or cast into the manifold. If they are screwed in, are they something an acura dealer shoul have?
Old 01-02-2002, 10:11 PM
New User
da6_b17a's Avatar
Default Re: fuel rail stud broke (Brian_92GSR)
don't worry, they come off.
Old 10-14-2003, 09:31 PM
MiraiZ's Avatar
Default Re: fuel rail stud broke (da6_b17a)
Hey ...this happened to me...does anyone know the part number and where I can get a replacement online?
Old 10-14-2003, 09:37 PM
IN VTEC's Avatar
Default Re: fuel rail stud broke (MiraiZ)
I had an issue with having only one usable stud when we switched the GS-R manifold for a Skunk2 manifold. I ended up using (2) M6x1.00x22mm flange bolts from the hardware store and using the stud in the middle as a placeholder.
Use a set of pliers to screw the stud out, or you can cut parallel faces onto the stud and use a wrench. Go to the hardware store and buy 6mm flange bolt of the appropriate length for your application. 22mm length might not be right for you.
Old 10-22-2003, 07:34 PM
MiraiZ's Avatar
Default Re: fuel rail stud broke (IN VTEC)
anyone else know the size for the OEM fuel rail studs?
Old 10-22-2003, 07:46 PM
tilt's Avatar
haha. I ended up doing the exact same thing with my skunk2 swap (2 of the fuel rail studs broke). I felt like i was ghetto-rigging the fuel rail going to the hardware store piecing parts together to bolt it down. But now i feel much better knowing im not the only one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I had an issue with having only one usable stud when we switched the GS-R manifold for a Skunk2 manifold. I ended up using (2) M6x1.00x22mm flange bolts from the hardware store and using the stud in the middle as a placeholder.
Use a set of pliers to screw the stud out, or you can cut parallel faces onto the stud and use a wrench. Go to the hardware store and buy 6mm flange bolt of the appropriate length for your application. 22mm length might not be right for you.</TD></TR></TABLE>
Old 10-23-2003, 12:05 AM
IN VTEC's Avatar
M6x1.00x22mm for the center one and M6x1.00x35mm for the two ends on GS-R's, and they're all M6x1.00x22mm studs on the ITR manifolds.
InTheZoneAC
04-09-2013 05:04 PM
type Gendy
11-13-2007 05:41 PM
central_driver
08-28-2007 12:43 AM
AzntaggeR
04-03-2004 07:30 PM
zilverz
05-19-2002 09:50 PM
Quick Reply: fuel rail stud broke
