E-Brake locked up on rear passenger side!
So I pulled my E-Brake up a little too hard, and my right passenger brake is totally locked. Usually when I let the E-Brake down, it makes a "click" sound, when the brakes release. This time when I let it down it didn't make the click sound. Also when I pull up on the E-Brake, it is a lot easier to pull up than usual; until about halfway up, when it gets really hard to pull. My E-Brake has been stuck like this before, but when it gets stuck I can pump the brake and it will release. Not this time. I took up the carpet and center console to see if the cable was sliding in and out of the housing properly, and it is. Please help!
Re: E-Brake locked up on rear passenger side!
had same problem with my 00 integra gsr abs!!! i had to replace the whole caliper and while i was at it put all new brake pads ETC! and rebleed the lines! its not hard and well worth it!
bleeding 98-01 integras are
f1 f2
r4 r3
sequence! goodluck
f1 f2
r4 r3
sequence! goodluck
