DA 93 INTEGRA LS FAILED CA SMOG YEAH!
Old 08-23-2016, 06:25 PM
wardseg6's Avatar
Default DA 93 INTEGRA LS FAILED CA SMOG YEAH!
DA 93 INTEGRA LS FAILED CA SMOG YEAH! WELL NOT YEAH BUT YOU KNOW WHAT I MEAN......Heres the twist...it has 277,072 miles on it and its the original motor. Guys help me get to 300K so I have stories to tell my grand kids about how I had an Integra that made it up to 300K.
FAILED SMOG NUMBERS
15 MPH ----HC (PPM) CO (%) NO (PPM)
MAX 89 MAX 0.37 MAX 495
Measured 171 Measured 0.56 Measured​ 3200 !!!!
25 MPH---- MAX 54 MAX 0.36 MAX 746
Measured 71 Measured 0.24 Measured 862
Things done before smog was done but didnt matter when the tech said I failed...
Cap and rotor
NGK blue wires and spark plugs
New air filter
New fuel filter
new timing belt
new muffler and piping
Most likely faulty CAT
I have extra new 02 sensor that I didnt install
Timing is off -26
Tech missed the rollers and went reversed and a plume of blue smoke came out exhaust.
I should do a compression test before doing any of these fixes before calling it quits......
ANY FURTHER SUGGESTIONS???
Old 08-24-2016, 09:08 AM
Prudz_lude's Avatar
Default Re: DA 93 INTEGRA LS FAILED CA SMOG YEAH!
Replace your cat. You listed a bunch of parts that barely effect your emissions yet said you didn't do the one thing that has the biggest effect.
Old 08-24-2016, 09:18 AM
-Intl Steve Krew
Caoboy's Avatar
Fix your timing before spending money on a cat.
Old 08-24-2016, 01:19 PM
wardseg6's Avatar
readings
Old 09-15-2016, 06:19 AM
wardseg6's Avatar
Update:
I put Lucas Oil Stop Leak and set the timing at +-16 TDC and Seafoamed it. Still need to replace 02 sensor and get it retested.
Question:
I cant seem to find a clear pic of it anywhere but if the following illustration was the timing marks on crank pulley the one in the middle of the 3 is -+16 TDC correct?
- <------ (+-16TDC)
Old 09-16-2016, 12:55 AM
wunfstgsr's Avatar
Deff fix your ignition timing and o2 sensor!
acespider
02-17-2012 10:15 AM
87 SiviK Si
05-31-2011 09:49 PM
RED DA
11-12-2007 02:05 AM
93B18
03-29-2004 04:16 PM
Quick Reply: DA 93 INTEGRA LS FAILED CA SMOG YEAH!
