cars jerks alot!!
Old 10-07-2001, 01:59 AM
vti-R's Avatar
Default cars jerks alot!!
i noticed that my car jerks alot and really bad everytime u let go of the accelerator.. it also jerks when u press the accelerator but it is not as bad..oh yeah it only jerks in 1st and 2nd gear.
thanks
Old 10-07-2001, 02:53 AM
New User
Rain_man's Avatar
Default Re: cars jerks alot!! (vti-R)
That happens to me as well, but I think it has to do with either a overly sensetive gas pedal (too much tension) or that I just need to drive more smoothy.
Old 10-07-2001, 02:14 PM
Grumpy Old Man
Veritas-Aequitas's Avatar
Default Re: cars jerks alot!! (Ein)
This happens on my car too...Anyone out there have a answer?
Old 10-07-2001, 02:15 PM
New User
slowerthanu's Avatar
Default Re: cars jerks alot!! (ReBornGSR)
Our cars are a bunch of Jerks!!!
Old 10-07-2001, 02:20 PM
wyv
wyv's Avatar
happens to me too. i just push the clutch in before i take my foot off the pedal - no jerk.
Old 10-07-2001, 02:55 PM
vti-R's Avatar
Default Re: cars jerks alot!! (wyv)
would loosening the gas cable be any good.
Old 10-07-2001, 03:37 PM
New User
Quisto's Avatar
I think it has to do with the tranny changing between the drive gears and coast gear. you can feel it more in 1st and 2nd because they are shorter gears.
Old 10-07-2001, 03:51 PM
New User
cyberhide's Avatar
Default Re: cars jerks alot!! (Quisto)
I have been having a similar experience.. when at low rpm's in 1st and 2nd and letting go of the gas.. i think the lack of gas at low rpms causes a bit of jerking. Our engines are basically saying they need more gas when yur down below 1.5k rpms
Old 10-07-2001, 03:54 PM
Luke's Avatar
Default Re: cars jerks alot!! (cyberhide)
Isnt it just a case of rapid throttle response with a tuned 4 pot, get the same on the blade. I use higher RPM's and tend to be more carefull dipping the clutch
Old 10-07-2001, 05:33 PM
New User
Rain_man's Avatar
Default Re: cars jerks alot!! (luke)
Do any of you guys have a aftermarket clutch? I've driven my friend's GSR's with stock clutches and they don't jerk as much as mine with a ACT clutch.
I have noticed that their gas pedal is looser too.
What do you mean by a tuned 4 pot and get teh same on the blade?
Old 10-07-2001, 06:40 PM
flex97itr's Avatar
this may sound stupid but that happend to my friends car and it turned out to be his tb... the flap was getting stuck... pull of your intake and clean it up and visually inspect it while turning it to see if thats the case.
Old 10-07-2001, 08:30 PM
Comptech98GSR's Avatar
Default Re: cars jerks alot!! (flex97itr)
mine does the same thing, but seems to happen less when the car is just warming up, and it is still cold.hmmm. Anyone know why this happens, i would love an explanation, as it is so annoying and embarassing, with a girl next to you, and u are shaking her *** to death.
Old 10-07-2001, 09:27 PM
New User
Isaac's Avatar
Default Re: cars jerks alot!! (Comptech98GSR)
Exactly, that's how my car is too. It's not as bad, but then it gets worse and that's how it is on my bike as well. I thought that it might be the clutch getting old, but there's only 50,000 miles on my clutch, but who knows?
Old 10-07-2001, 09:31 PM
Default Re: cars jerks alot!! (98 GS-R)
i'm sure it is clutch or tranny related, wish someone had an answer though
Old 10-07-2001, 09:52 PM
New User
Rain_man's Avatar
A worn clutch will cause the the car to be smoother actually because it will slip before it starts to grip the flywheel.
A racing cluch (like those six pucks with the crazy pressure plate) will be very jerky, since it grips so quickly and so hard. The clutch is more like an on and off switch. That's why I'm asking what kind of clutches you guys have.
Old 10-07-2001, 10:37 PM
i have stock clutch with 44K miles
Old 10-07-2001, 10:52 PM
lucas569's Avatar
**** mine too! i have a b18c1 powered civic.
this happened to my friends car which is a hyundai btw and it turned out to be the rear motor mount.when he let go of the gas pedal you could feel a small jerk like the motor rocking.
Old 10-08-2001, 06:55 AM
SpeedMonkeyRacing's Avatar
it reads playboy too much..that's why it likes to jerk alot
Jeff-
EJeff8
32
11-13-2010 08:32 AM
B16A2JK59
11-05-2009 04:23 PM
luderollin
09-08-2005 02:05 PM
tallblondkid
09-15-2004 01:24 PM
Integra_Boi
06-13-2002 08:50 PM
Quick Reply: cars jerks alot!!
