car smoking white rough idle hesitates big time and wants to die when i get on it.
just pulled the intake manifold off and all the lines to clean it out. installed it back on and now she's smoking white and has a rough idle any clue? smell's very rich and has no power it bogs out when i give it gas in gear.
Old Fart
Re: car smoking white rough idle hesitates big time and wants to die when i get on it
White smoke would indicate a blown HG, but pulling the IM off will not blow the HG, recheck all the lines to the IM, Sounds like you have plugged something in wrong, [coolent line into vac line].
MM&Y of car and any mods??? 94
This happened to me once. Did you put back on the MAP sensor's O-ring? I forgot to put it on once and same thing happend, white smoke, smells rich. Check it out
dude it cant be the head gasket. it was running fine before the intake manifold gasket swap. compression checks out good did a leak down test its not the head gasket so?
could be leaky injector o rings or an injector stuck open just dumping fuel, i had this problem on my other car. check the oil to see if it smells like gas
I didn't even read your first post, just the title lol. It's the intake manifold gasket, you should have sprayed it with copper gasket spray. Coolant runs through a port in the head to manifold, it is leaking into the intake runners.
