can someone check alternator fuse on their LS?
Old 05-31-2003, 08:38 AM
civcexcoupeblack's Avatar
Default can someone check alternator fuse on their LS?
I have a 95 ls in a 98 civic. And I keep blowing my alternator fuse. Im thinkning maybe its not big enough, since my civic uses only a 7.5 . IF you could check your integra, that would be great.
Old 05-31-2003, 09:05 AM
New User
FORCED FED TEG's Avatar
Default Re: can someone check alternator fuse on their LS? (civcexcoupeblack)
Nothing mark alternator fuse. Maybe this will help. from alternator to ignition is 15A , from alternator to battery is 100A, and battery to ignition is 50A
Old 05-31-2003, 10:02 AM
4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civcexcoupeblack &raquo;</TD></TR><TR><TD CLASS="quote">I have a 95 ls in a 98 civic. And I keep blowing my alternator fuse. Im thinkning maybe its not big enough, since my civic uses only a 7.5 . IF you could check your integra, that would be great.</TD></TR></TABLE>
That's the right ampage for that fuse... I had the same problem in my Teg with that fuse blowing... I never figured out why it kept blowing, but when I replaced it, I used a 10A fuse and it hasn't blown since... HTH...
nolimitlowrider
03-16-2019 06:49 PM
lsb18_hatch
04-06-2009 03:02 PM
22psicrx
10-12-2006 01:40 PM
Quick Reply: can someone check alternator fuse on their LS?
