Starter issue
Starter issue
hi guys i bought a 95 ls with a bad motor. I swapped in a b18b out of a 97 integra everything is cool with the swap now the starter is acking up. It was just replaced now its clicking. Itll start is i keep messing with the key but it clicks the first couple times i turn the key. The starter was perfect before the motor swap.
Old Fart
Re: Starter issue
There is no ground at the starter, the starter grounds through it's case.
Your problem may be a grounding issue, to check, leave door open so dome light stays on, watch dome light as you try and start the car, if the dome light goes out when you hear the "click", you have a grounding problem, redo your main grounds, batt. cable clamp and post, batt. to chassis ground and chassis to engine ground.
If dome light does not go out it is not a grounding problem and is most likely the high current contacts in the starter motor solenoid... https://honda-tech.com/forums/showth...+starter+motor 94
Old Fart
Re: Starter issue
Never seen a ground lead/cable on and Integra starter, and all the wiring diagrams I have looked at do not show one.
Some thing added maybe, post a pic of them.
Not even sure why it would need one as the starter grounds through it's case to the engine, [transaxle] 94
Re: Starter issue
i cant find one. but ill take a pic of mine. its a brown wire.
People have issues with this because they put the wrong starter in their car and the ground wire burns and melts.
hondachris1994
12
11-09-2017 05:15 PM
