B18A Block build
Old 08-18-2005, 09:31 PM
testingcheck's Avatar
Default B18A Block build
I was wondering what are some internals that should be built on my B18A engine inorder for it to be able to handle high power? I was told to get piston rings, pistons, rods, rod bolts I am not sure which brand is good quality and cheap. Is there anything else that should be changed?
Old 08-18-2005, 09:42 PM
bump**
Old 08-18-2005, 09:46 PM
ALLMOTA92EG's Avatar
go with some p30(oem) pistons and some arp rod bolts.
Old 08-18-2005, 09:51 PM
p30 with rings? Will they fit a B18A (non-vtec)? Also will I be needing anything else for my engine to handle high power?
Old 08-18-2005, 10:18 PM
HT Black OPs
00IntegrAllmotoR's Avatar
Default Re: (testingcheck)
build the head to withstand higher rpm's
Old 08-19-2005, 04:28 AM
Will you make something up for me please?
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by testingcheck &raquo;</TD></TR><TR><TD CLASS="quote">p30 with rings? Will they fit a B18A (non-vtec)? Also will I be needing anything else for my engine to handle high power?</TD></TR></TABLE>
What is your definition of "high power"? What are you building it for? Turbo? N/A?
Depending on your power goals, you can spend $1000 or $5000 easily.
Old 08-19-2005, 06:13 AM
Well I am going to turbo my car. So when I rebuild my engine I should get P30 pistons with rings new rods and rodbolts? Is there anything else that would help?
Old 08-19-2005, 06:29 AM
eight equals equals equals D
Tim2179's Avatar
If you are going turbo, then don't get the p30 pistons. The P30s are OEM B16 pistons and will raise your compression. Lower compression is better for boost. Get the P30s if you're going N/A.
Old 08-20-2005, 07:43 PM
what kind of pistons w/rings, rods and rod bolts should i get with boost?
Old 08-20-2005, 08:21 PM
Lauj87's Avatar
The Good Stuff is never too cheap..i would go JE pistons and wristpins...high compression or low compressing depending if your gonna boost or not.......and while your at it Get RODS and all your bearings too...
Old 08-20-2005, 09:56 PM
TurBoTeG's Avatar
id go with 81.5mm CP pistons with somewhere around 9:1 comp. Id also go with Eagle H Beam rods...no need to buy rod bolts seeing the Eagles alread come with them.
Old 08-20-2005, 10:17 PM
Anything other internals I should change? If not I will get my engine rebuilt with those two parts added.
Old 08-21-2005, 12:51 AM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by testingcheck &raquo;</TD></TR><TR><TD CLASS="quote">Anything other internals I should change? If not I will get my engine rebuilt with those two parts added.</TD></TR></TABLE>
Im going with cp pistons and eagle rods myself. For my build im also picking up some arp headbolts, oem honda bearings, oem headgasket, oem timing belt, oem water pump. Maybe even possibly sleeving it, but it depends on the budget i have after summer
Old 08-21-2005, 01:12 AM
whoneedzvtec's Avatar
Default Re: B18A Block build (testingcheck)
like turboteg said. exept instead of h beams go wih i beams. they r built for turbo. h beams r for all motor. and if ur looking to push more than about 15 psi, u should also sleeve it. good luck
Old 08-21-2005, 08:08 AM
kdawgy2k1's Avatar
Wassup man? you wanna make sure the bottom end is gonna be trouble free so suggest you get the block lined bored... and if the crank has over 125k miles get it checked out and balanced.. good luck...
Old 08-21-2005, 08:20 AM
smoovy's Avatar
Default Re: (kdawgy2k1)
I am personally going to be using Wiseco pistons and Eagle H-beam rods.
Old 08-21-2005, 08:27 AM
My engine right now has 300,xxx KM and I am going to rebuild it asap. I am planning on pushing like 12 psi max.
Heres what I have come up with:
- cp pistons and eagle rods
- arp headbolts
- new pumps and belts
- Everything else rebuilt if needed
Old 08-21-2005, 10:08 PM
Am I correct?
Old 08-21-2005, 10:15 PM
Deluzional's Avatar
sounds good to me, also make sure you pick up new bearings, headgasket
davidjames1983
05-21-2012 05:27 AM
hpimichael02
08-13-2008 02:19 PM
rhdcivic05
11-21-2006 06:23 PM
coronadrinker
10-01-2005 04:23 PM
Quick Reply: B18A Block build
