June FS Thread
Moderator
June FS Thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
4) NO WTB ADS!
Re: June FS Thread
For Sale:
- Full Race IC 2.5" hot side 2.5" outlet rated for 750hp 20"x10"x3'' 325.00
Re: June FS Thread
Text me for fastest response 352-299-4653
Gato 8 injector Gsr intake manifold 800 shipped an paypaled
8 id1000cc injectors 350$ a set shipped an paypaled
Tial 46mm wastegate 300$ shipped an paypaled
Clutchmasters twin disc 650$ shipped an paypaled
Skunk2 Tuner 3 cams 450$ (extremely low mileage)shipped an paypaled
Benson sleeved, blueprinted & balanced, 84.5mm bore Wiseco 10:5:1-10:8:1 w/ upgraded cp wrist pins, Oliver I-beam rods, original gsr crank micropolished 2500$
1200$ shipped an paypaledB18c1 fully built head ported, 3 angle valve job, supertech dual valvesprings and ti retainers, supertech flat faced valves, bronze valve guides, ferrea valve seals, supertech lockers, and keepers
Re: June FS Thread
Contact: 804-337-8376
For Sale:
For Sale:
- Brand NEW Crower Stage 3 Turbo/Allmotor Cams B series Part no. 63403-2 - $350
- OBD0 Alternator - SOLD
- Used STR Cam Gears with Big Bolts - $160
- Precision 1000cc - SOLD
- 15’’ Weld Magnums With 275/50/15 M/T Drag Radials (Tires have 2 miles) - $700
- Brand NEW Crower 1mm Oversize Intake Valves and .5 Over Exhaust Valves - $200
- Used GSR GRP aluminum rods with ARP 2000 bolts and use an oversized wrist pin. $300
- Reconditioned from CP, CP Pistons 83mm 9.0:1 compression. With fresh high temperature ceramic top coating and Molly skirt coating. Includes all locks, wrist pins, new ring set and spec sheet. - $425
- New Mac Boost Solenoid with Barb and Breather Fittings. $65
- Used Autometer Tach (2-5/8 I believe?) - $10
- Used B&M Pressure Gauge - $10
Re: June FS Thread
mw pro 14- $ 550 -Works great, used in a 600whp K Series
Motec E888- $900 Used for 3 RTA seasons, Will supply serial number to interested persons.
Re: June FS Thread
FS: (qty 1) Tilton Racing Pressure Plate, high ratio - $250 shipped to the lower 48
.refurbished with 0 miles
.diaphragm replaced
.high ratio diaphragm
.includes new pressure plate bolts
.no clutch packs
.no flywheel or +$200 for 10lb Tilton flywheel w/ used Honda flywheel pilot bearing
.diaphragm replaced
.no clutch packs
Re: June FS Thread
706-346-6024 matt.stover@comcast.net
FS: Ferrea Dual Valve Springs(Only)....the 75lbs version
$100 shipped
$100 shipped
Re: June FS Thread
All prices are + shipping and paypal fees.
Rolling shell-$10k non neg price! Don't ask! This is a crackhead price! 25.5 cert chassis, Progress custom coil over setup, custom front, shaved bay, custom flat paint by Goolsby customs, fiberglass tailgate, CCC spoiler, carbon hood, weld ...rear skinny's, Exospeed 15x9 fronts with 26x9 toyo's, Kirky seat, stroud window net, custom staging brake, stroud parachute, sumped tank, Mfactory LCA, and I don't know what else I'm forgetting. I also have enough carbon wrap to do the hood, tailgate, and rear diffusers. I will do that before it leaves here.
Chase Bays b series mil spec harness-$1000
New Honda engine bearings-$125
There are 26 bearings in there. Probably $250 worth.
15 used Crower valve spring retainers. 1 missing for some reason.-$75
AEM fuel rail for b series with sample valve and SX regulator-$150
Hks bov-$50
Unknown intercooler-$50
F22 drag turbo manifold-$50
BDL 70mm throttle body-$200
MSD 75314 4cyl ignition box w traction control-$500
Stock B18C1 longblock, new cam seals, rear main seal, oil pan gasket, valve cover gasket, oil pump, water pump, tensioner, and timing belt. Was gonna be my beater engine, do it's got everything you need new to make it run for a long time. $1100 timing belt and cover not in pic. also, will have stock oil pan and pickup installed.
Hks bov-$50
Re: June FS Thread
Have a new b series turbo manifold for a ek it places the turbo in the grill opening. Its a t4 flanged and dual mvs gates looking to get 700 obo any question pm or text me 2402161030 i can ship and i take paypal thanks
Re: June FS Thread
PICTURES HERE
http://www.6thgenaccord.com/forums/a...p?albumid=1205
Or The Photobucket Account (Brothers Account)
Got some h22 turbo parts from my build I never got to finish . I'm located in Brooklyn nyc . Prices don't include shipping . You could reach me thru the PM or thru email which is h0od11306@gmail.com PLEASE IN THE EMAIL SUBJECT ADD THE PART YOU ARE ASKING ABOUT AND THAT YOU ARE FROM 6THGEN Accord (I Have Posted Else Where)
Prices are somewhat negotiable
H22 benson block from laskey racing $2800
Brand new never used
H22 endyn full race port and polish with bronze guides and skunk2 valves $900
H22 head with full valve train ferrea valves retainers keepers skunk2 pro1 cams with pro cam gears $2000
Sheepey h22 twin scroll top mount.
Brand new never used $700
H22 aem coil pack with emp and twin fire $500
H22 valve cover with an fittings $150
H22 golden eagle intake manifold brand new with golden eagle fuel rail $550
Greddy Timing Belt $100
H22 moroso pan used with brand new oil pick up $300
Saenz transmission h22 gear set brand new $3000
Precision turbo 6765 DBB
$1000
Spec twin disc used $400
golden eagle oil sandwich with stainless steel turbo oil line (earls) $125
alternator relocation bracket to fit the top mount $ 70
$1000
Re: June FS Thread
Competition Clutch H2B Twin disk
Only a few passes on clutch. This kit has an aluminum flywheel unlike the newer steel one. $800 OBO..
Ecliptech Shift I Rev progressive shift light BNIB $*** [sold]
Re: June FS Thread
*Please Read Whole ADD*
1) I will not part out any of the packages do not PM me asking to sell you 1 rim/tire. If they are posted together in a package with a total price they will NOT be separated.
2) The prices are firm if you do not like them please do not PM me, if you offer less then my asking price I will not respond.
I hate to have to go in this direction but due to some changes in my life I have to get rid of one of my cars. So with that I decided to part out my drag car. I have bought and sold lots on here so buy with confidence. I can provide numerous vouches if you require. All prices are shipped and in US dollars you must pay paypal or send as a gift. I am located in Canada but do not let this stop you from buying. Do not bother lowballing me I will completely ignore them. If you don't like the prices feel free to buy elsewhere.
Text or PM only 1 306 551 5139
- Race motor brand new never used - $3650 shipped (Does not come with valve cover $200 more for that) *WILL NOT PART OUT. SOLD AS A WHOLE*
Benson sleeved LS-vtec engine (sleeved prior to benson engraving the block)
84mm bore
GRP billet aluminum rods
Custom ross 11:1 pistons w/gas ports
JE custom wrist pins
O-ring'd block and reciever grooves in the head
SCE Copper head gasket
Moroso 5qt oil pan
JG cylinder head GSR
cnc'd
ferrea bronze guides
JG .5mm oversized flat face valves
JG valve springs and retainers
fresh valve job and surface
Highly polished front of cylinder head looks amazing
Brand new skunk2 pro 1 camshafts
- B series PAR Dog Box Gearset 2.9/2.0/1.4/1.09 With a 4.4 Final drive and cuff support maybe 10 passes with brand new M-Factory Diff installed in a re-endforced case - $4650shipped
Chase Bays CM1 Engine Harness - Honda/Acura B / D / H Series CHASSIS: 92-95 Civic | 94-01 Integra ECU/ECM: OBD1 INJECTORS: ID-2000 ALTERNATOR: OBD0/OBD1 IGNITION TYPE: OBD1 Distributor - $450 shipped
AIR Carbon Fiber intake manifold(Fits both gsr and b16 heads dual bolt pattern) - $900 Shipped
B series Carbon Fiber Valve Cover - $400 shipped
B series Oil Catch Can, Comes with valve cover, 4 lines(2 for head and 2 for block), and oil catch can - 350 shipped
Sprinwerks Slicks and Skinnies *WILL NOT SPLIT THESE UP DON'T ASK*
Fronts are 26x10x15 with bead lock(4x100 bolt pattern)
Rears Skinies are 25x4.5x15 (4x100 bolt pattern)
$1500 Shipped
Fuel System - 800 shipped
- 2x Bosch 044 with relays
- -8an Feed and return braided lines
- 5 gallon fuel cell
- Precision GT4294 journal bearing, 4" V-Band . Rated for up to 850hp, small chip in one fin *see picture* - $650 shipped plus paypal
- Garett 950hp Dual Back door intercooler(core size is 3.5"x12"x24") with 3" piping flanged for a tial 50mm BOV- The outlet piping on the front mount was squished a bit during shipping when I received it. This set up is used. - $490 shipped
- 4" Aluminum exhaust for EG Hatch, 3" vband with clams, one spot was cut for shipping purposes and will have to be re-welded or put a new vband clamp on it. There is a dent on the tip of the muffler from shipping. (please note the exhaust is not properly lined up for the picture - SOLD
- KOYO aluminum Rad with 12" mishimoto fan and hoses with Rad cap (ALL BRAND NEW) $400 shipped
- 2.5" steel cold side piping with clamps NO BOV
Front mount intercooler roughly 20"x9"x3" (made 475hp no problem) - $150 ship will not split this up
- AZ racing GSR Girdle - $80shipped
- Eg traction bar (garage built so not the nicest) - $100 shipped
- J's Racing CF air Duct for EG (passenger side) -$125 shipped
Sorry for not having my name in all the pics. I recently packaged everything up to move but can take better picks for people who are only seriously interested. The only different from the parts now compared to when I took these pics are they are now in packaging ready to ship.
84mm bore
Moroso 5qt oil pan
cnc'd
$1500 Shipped
Re: June FS Thread
B-series LS Manley turbo tuff rods w/ 83mm CP pistons 9:8 and CP upgraded wrist pins $900
$125 catch can w/ -10 lines -10 AN fittings & battery tray bracket.... $50 B-series oil pan w/ -10 male fitting for turbo return line.....$50 B-series shift linkage
Re: June FS Thread
GSR head for sale. All new supertech valves with inconel exhaust valves. 1000 OBO
Edelbrock 4730 Cams brand new in box. 450 OBO never been opened.
Golden eagle Sleeved and sleeved B18C5 with Crower I beam with wiesco 9:1 compression pistons with upgraded pins. Zero miles. Never had a head bolted on since it was at the machine shop. Comes with pan and oil pump. Best offer
PM me for pictures.
PM me for pictures.
Re: June FS Thread
Forsale:
Borg Warner Class Limit 72mm Billet Turbo 1.10 or 1.25 Housing your choice, Turbo has 2 dyno pulls and 1 event making (2) 1-3rd gear passes.... Ive Made over 1085whp on a dyno jet at 45psi on the cast version... $2000 (PayPal fees Included)
Precision GT4272r 1.28 housing, Ball Bearing, Billet wheel, turbine wheel has damage but the unit still works... $1000obo
All parts arn't including Paypal unless noted or shipping.... If you are serious we can work sumthan out..
Text 714-388-7303 Text 714-388-7303 Text 714-388-7303
PLEASE SERIOS BUYERS ONLY, PEOPLE WHO HAVE MONEY, NO WISHES, NO HOPES, SERIOUS PEOPLE
30% restocking fee applies...
Re: June FS Thread
AEM PN:30-1060 OBD II brand new never used $600obo
Skunk2 Racing B-series radiator hose kit like new $80
Skunk2 Racing billet vtec solenoid like new $80
MSD coil p/n8253 $80
Brand new Evolution Industries b-series light weight flywheel 11.5lbs $160
Used Moroso battery box only $75
Used Garrett T4 1.28 A/R housing for all GT42 and GTX42 $320
Hondata S300V2 brand new still in the boxes ea $350
Moroso steel oil pan 4qt used $160
Climax B-series used $100
Innovate wideband used two events like new $200
