importparts.com - Wheels, Tires, Brakes, Suspension Garage Sale!!!
All parts are BRAND NEW unless noted otherwise. This list is updated daily and sold items are removed so it you still see an item listed, it is still available.
UPDATED 12/30/14
4 x Enkei RPF1 16x8 4x100 +38 Silver: $800
4 x Toyo Proxes R1R 225/45ZR16: $600
Buy the set mounted/balanced for $1350!
4 x KLUTCH SL1 15x8.5 4x100 +17 BLACK: $650
4 x Toyo Proxes R1R 225/45ZR15: $520
Buy the set mounted/balanced for $1120!
Ingalls 81260 14mm Fastcam camber kit: $40 pair
Ingalls 3556 front ball joint camber kit Prelude: $100 pair
Front lower tie bar 92-95 Civic: $15
Tokico HP front shocks 86-92 Supra: $100 pair
Tokico Illumina adjustable rear shocks 90-97 Accord: $200 pair
Goodridge stainless brake lines 96-00 Civic LX/EX w/ large front rotors: $100
Goodridge stainless brake lines 01-05 Civic w/ rear disc: $100
Axxis Metal Master 23-273-01 front pads 88-00 Civic: $25
Axxis Metal Master 088-1428M front pads 90-93 Accord: $25
HARDRACE
6594 rear LCA bushings DC5/EP3/FD: $35
6489 spherical rear LCA bushings 92-01 Prelude: $70
6622 forged front roll center adjuster S2000: $200
HARDRACE
6419 92-01 Prelude Rear Lower Lateral Arm (pillow ball): $150
HARDRACE
6297 front sway bar 18mm bushings EG: $15
6359 front strut bushings EF: $15
6258 rear sway bar end links DC5/EP3/FD: $30
6259 front sway bar end links DC5/EP3/FD: $30
6488 front sway end links 92-01 Prelude: $30
HARDRACE
6691 front lower arm bushing kit 06+ FD Civic: $50
6136 front stabilizer end links EG: $30
6325 shifter bushings SOHC: $15
6347 shifter bushings DOHC: $25
HARDRACE
6490F spherical trailing arm bushing kit 92-01 Prelude: $120
6117 rear LCA EK: $80
6432F front lower arm bushing kit DC5/EP3: $90
Neuspeed sport springs 88-91 Prelude: $100
NRG 4pt brace 92-00 Civic, 94-01 Integra: SOLD OUT
SPW coilover sleeves EG/DC $30
Tokico Illumina front adjustable shocks 90-97 Accord, 96-99 CL: $160 pair
Revo Camber Kits
Rear 98-02 Accord, 01-02 TL, 99-03 CL: $50
Front & rear EG/DC: $65
Front 98-08 Accord, 97-01 Prelude, 01-04 CL, 99-08 TL, 04-08 TSX: $65
Front & rear 95-99 Eclispe FWD/AWD: $50
Spoon front & rear strut bar RSX DC5: $240 set
Ignited remote starter: $70
PLX DM-6 wideband A/R gauge: $130 open box
HKS Type 1 turbo timer: $70
MSD Blaster 2 coil: $30
Hawk HPS front brake pads Integra HB245.F.631: $45 each set
Cusco 1/1.5Way B16 LSD (LSD 318 C15): $1000
NRG Front Strut Bar Carbon 96-00 Civic: $30
SPW Front Strut Bar 98-02 Accord: $15
Front Strut Bar 92-96 Prelude: $10
Front Strut Bar 98-02 Accord: $10
Rear Strut Bar 98-02 Accord: $10
Neuspeed Sport Springs 01-05 Civic (rears were installed): $75
5Zigen Heidfeld Mesh 17x7 5x114.3 +42 Bronze: $750 set (1 left!)
5Zigen Heidfeld Mesh 17x7 5x114.3 +42 Silver: $750 set (1 left!)
USED Eibach Sportline Springs 98.02 Accord: $50
USED Set of 5Zigen FN01R-C 17x7 4x100 +42 Gun Metal w/ Falken FK-451 205/40SR17 tires: $700 obo
M&H 8.5/24.5-13 Slicks: $375 per pair (1 left!)
Re: importparts.com - Wheels, Tires, Brakes, Suspension Garage Sale!!!
1 Post
Ben,
I'm needing a single Rota Circuit 8. 16" with the 4x100 & 4x114 patterns. A good deal on a cosmetic blem/used/ open box is what I need, as I will have to have them all blasted and coated anyway.
Thanks
Thanks
