>>>Brake Pads, Lines & Rotors<<<
EMAIL ME FOR SPECIAL HONDA-TECH PRICING !
Email:sales@hardPARKED.com
Brake Pads
Stock brake pads are fine for the average driver. However, the driving enthusiast looking to enhance their car's brake performance has several choices. Compared to stock brake pads, performance brake pads generate more friction and work in a broader range of temperatures while reducing the possibility of brake fade at higher temperatures. Higher performing brake pads continue to work in an even higher range of temperatures and further reduce the possibility of brake fade.
brands: Hawk, EBC
Hawk
Hawk Performance HPS Performance Street Brake Pads
Hawk Performance HP Plus Brake Pads
Hawk Performance HT-10 Brake Pads
Hawk Performance DTC-30 Brake Pads
Hawk Performance DTC-60 Brake Pads
Hawk Performance DTC-70 Brake Pads
EBC
EBC Greenstuff Brake Pads
EBC Redstuff Brake Pads
BC Yellowstuff Street and Track Brake Pads
PM ME FOR SPECIAL HONDA-TECH PRICING!
Rotors
While changing brake pads may come as common sense upgrading or replacing rotors is often neglected. The pressure and heat generated by the brake pads rubbing against the brake rotors combined with the dirt and debris that gets between them wears away metal, slowly removing the material that was designed to act as a heat sink to maintain braking performance and efficiency. Once brake rotors have worn to their minimum thickness it’s time to replace them.
brands: Stop Tech, PowerSlot, DBA, EBC
PowerSlot
Power Slot Slotted Brake Rotor
Power Slot Cryo Slotted Brake Rotor
DBA
DBA Street Series Slotted Brake Rotor
DBA Street Series Gold Brake Rotor (Cross-Drilled & Slotted)
DBA 4000 Series Brake Rotor (6x6 Wiper-Slot)
DBA 4000 Series XS Brake Rotor (Premium Cross-Drilled & Slotted)
EBC
EBC Stock Replacement Rotors
EBC Sport Rotors
EBC Ultimax Rotors
Brake Lines
Stainless steel braided brake lines are an industry standard in the world of motor racing. These kits feature the finest quality stainless steel braided hose, which improves braking performance, eliminates the spongy feel of rubber hoses and provides superior resistance to corrosion.
Acura Brake Lines
Honda Brake Lines
Brake Fluid
Motul RBF660 Brake Fluid
RBF660 is filled in a nitrogen gas environment, increasing shelf life and all but eliminating contamination from absorption of moisture during storage. The wet boiling temperature far exceeds the requirements of DOT 3, 4 and DOT 5.1 and with an impressively high dry boiling point, vapor lock and brake fade during hard use is all but eliminated
Brake Pads
brands: Hawk, EBC
Hawk
EBC
Rotors
PowerSlot
DBA
EBC
EBC Sport Rotors
EBC Ultimax Rotors
Brake Lines
Acura Brake Lines
Honda Brake Lines
Brake Fluid
