Wheel weights on OEM wheels...
Old Aug 12, 2006 | 06:43 PM
mike9571's Avatar
Default Wheel weights on OEM wheels...
Im going to be purchasing some GSR swirlies/blades and I was just wondering if it is possible to get the wheel weights put on the inside?
Old Aug 12, 2006 | 06:49 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Wheel weights on OEM wheels... (mike9571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">Im going to be purchasing some GSR swirlies/blades and I was just wondering if it is possible to get the wheel weights put on the inside?
Of course! I prefer those on all my wheels (not only for aesthetics, but also for track wheels, where they get pressed onto the wheel by centrifugal force, instead of it pulling them off).
Here are some things to consider:
1. With most mounting shops, you have to ask specifically for the stick-on tape weights rather than the bang-on (clamp-on) weights that go on the lip.
2. Some shops don't keep the weights in stock. Call ahead. If they don't stock them, you can buy them yourself at any good auto parts store and bring them with you for them to use.
3. Make sure there's enough clearance between your brake calipers and the wheels for the weights to be mounted there. On some cars the clearance is tight and the weights could get knocked off.
4. Some shops charge a few bucks more for balancing wheels with tape weights instead of bang-on weights.
Old Aug 12, 2006 | 07:00 PM
mike9571's Avatar
Default Re: Wheel weights on OEM wheels... (nsxtasy)
Thank you.
The shop I work at has a balancer so I will buy the stick on weights and have one of the techs do it.
Old Aug 13, 2006 | 12:16 PM
ErichTL's Avatar
stick on weights look so much better appearence wise.. the only problems i've encountered is that they've fallen off on me in the past on several occasions..
Old Aug 14, 2006 | 12:00 PM
gabebauman's Avatar
Default Re: (ErichTL)
Yeah...I had the "Big'O'Tire" shop install wheel weights on the inside of the rim for my HX wheels. I hate those lip weights...they're ugly.
gosu08
Oct 22, 2010 09:17 AM
EdoMoto
17
Jul 12, 2008 04:41 PM
Mr.E.G.
Apr 24, 2007 03:58 PM
sambo_666
Apr 16, 2007 07:14 PM
Autoforma
Aug 20, 2005 11:24 PM
