Wheel Help : The paint is...
fucked up.
I was experimenting with all these polishing up ideas, by removing the paint. I used Jasco because I couldn't find any Aircraft paint stripper. The first "coat" didn't work too great, so I tried a second coating.
Here is how it looks today.
I am thinking I should sand it down, but any other suggestions?
I used the gel, not the spray can. that might be a reason.
i applied a thick coat. the paint would bubble up and MOST of it would be easily removable with water. but other stubborn bits i had to sand/dremel off the rest.
it takes time. but i got lazy and never finished the way i would like them to be. looks okay enough for me
What sanding materials did you use? I was planning on buying the gel next time anyways..so I could go over what I missed instead of spraying **** everywhere that I think missed (if you know what I mean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joebroni »</TD></TR><TR><TD CLASS="quote">You can get airplane stripper almost any auto parts store, even Oreillys carries it on shelves.</TD></TR></TABLE>
I looked for it already...couldn't find it.
)<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joebroni »</TD></TR><TR><TD CLASS="quote">You can get airplane stripper almost any auto parts store, even Oreillys carries it on shelves.</TD></TR></TABLE>
I've been to Lowe's twice now, haven't seen one can. :-(
Maybe I should try Home Depot? I need to go back anyways, to get some sanding things so I will try both places, possibly.
i used 800 grit sandpaper, scotch brite, and steel wool.
Scotch brite worked the best to get rid of the stubborn pieces. i still got left over steel wool that i didnt even use. i SHOULD sand it with 1000 and 2000 grit and then a metal polish.
The aircraft stripper i believe i got it at home depot. the jasco one i got at a paint store, but home depot has it too. if you cant find it, ask them
have fun trying to take off the OEM primer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobyahead »</TD></TR><TR><TD CLASS="quote">damn i hope you took the rims off... cuz that paint remover stuff is no joke. it will eat thru your tires slowly but surely. </TD></TR></TABLE>
I put index cards all around each time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leboeuf11 »</TD></TR><TR><TD CLASS="quote">what are you going to do after they are stripped?? If you are tell me how to do it so it sticks . i have a set of cw itr stock wheels i would love to paint gunmetal</TD></TR></TABLE>
I don't don't plan on wasting more money to paint them.
Oh well, I am on steelies for now so I am taking this real slow.
