Whee problem, please help.
Old Sep 24, 2010 | 06:19 PM
tooflyboinick's Avatar
Default Whee problem, please help.
Ok, so today I had to replace my wheel stud on my car because they broke from mechanics in the past over-torqueing them. Anyways, because i didnt realize the problem fast i was driving with loose lugs basically which made the "holes" bigger and they said over-time my lugs might just go straight through the wheel and i wont be able to tighten them any more.
is there a solution to this problem? like a washer I can buy or something?
Old Sep 24, 2010 | 06:29 PM
CountDracura's Avatar
Default Re: Whee problem, please help.
Are you referring to the holes in the rims in which the studs go through and the lug nut secures?
Old Sep 24, 2010 | 07:32 PM
yes i am.
Old Sep 25, 2010 | 04:07 PM
I've seen this problem before but never a solution other than replacing the rims. Tapered lugnuts may work if the holes are only slightly elongated and properly torqued. Have you spoken to the shop where the work was done and asked for a full replacement?
Old Sep 29, 2010 | 06:52 PM
Originally Posted by Kedwin
Hello guys!
Sounds like wheel bearings to me a lube job may help, or you may need new ones. Could possibly be a brake thingy, too. where they are maybe hanging and or rubbing or grinding on the rotor.Just from my experience with my many cars.
WTF?
Getownit
Dec 18, 2010 08:01 AM
gsbadbmr
Nov 29, 2005 11:28 AM
dirtyapes
26
Jul 19, 2004 04:49 AM
MidNiteMysT
Aug 25, 2003 04:04 AM
nargenar
Jun 7, 2002 07:26 PM
