Weights on LS Mesh
Old May 10, 2006 | 06:05 PM
HBADGE's Avatar
Default Weights on LS Mesh
For those who are rockin the ls meshs.. when you got your wheels balanced, did they put the weights on the inside or outside of the rim?
Old May 10, 2006 | 06:19 PM
Smash03's Avatar
Default Re: Weights on LS Mesh (HBADGE)
That depends on where it needs to be balanced.
Old May 10, 2006 | 07:41 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Weights on LS Mesh (Smash03)
You could be referring to two different things.
1. Wheels are balanced along both the outside edge (around the face of the wheel, facing the outside of the car) and the inside lip (around the inside face of the wheel, towards the inside of the car). This is what Smash03 was referring to; the weights are placed wherever the balance was needed.
2. However, maybe you are referring to the difference between "clip on" weights, which are banged onto the outer edge of the wheel lip, and "tape" weights, which have double-sided tape to stick them onto the inside surface of the wheel just inside either lip. Most shops use the "clip on" weights unless you specifically ask for "tape" weights.
Old May 11, 2006 | 05:03 AM
HBADGE's Avatar
Default Re: Weights on LS Mesh (nsxtasy)
Thanks for the info. Exactly what i needed!
Soulless
Mar 30, 2011 01:05 AM
huge230
Apr 6, 2010 02:24 PM
smash fascism
Apr 10, 2005 10:50 PM
G3NR8
Mar 6, 2005 04:34 AM
Fuster_Cluck
Jan 23, 2004 06:27 PM
