Tire Pressure
Old Apr 18, 2005 | 04:43 PM
Floored's Avatar
Default Tire Pressure
I am new to having aftermarket rims and was wondering what I should be doing for tire pressure. The tires I am using are considerably larger than the 13" stockers (205/45/16's) Right now there is about 30-35 psi in them and I just invested in new Fuzion ZRi's and dont want them to go to waste.
Is the stock wheel pressure still ok to use or will it be off because of the change in tire size?
Old Apr 20, 2005 | 06:57 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Tire Pressure (Floored)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Floored &raquo;</TD></TR><TR><TD CLASS="quote">Is the stock wheel pressure still ok to use or will it be off because of the change in tire size? </TD></TR></TABLE>
The pressure recommended by your car's manufacturer (in the owner's manual and/or the door jamb sticker) is a good place to start. Try it. If you find that you need to change it, then do so - either to adjust the handling, or due to uneven tire wear (more wear in the center than both edges is a sign of overinflation, and more wear on both edges than in the center is a sign of underinflation).
pnoi_01dc2r
May 28, 2007 07:24 AM
jonzel
Dec 7, 2006 10:20 AM
sporty240
23
Aug 25, 2005 06:25 AM
pphan3
Mar 10, 2005 05:41 PM
mugen92acintls
Mar 6, 2004 02:12 PM
