stretching tires
Old Nov 17, 2006 | 03:20 PM
Fat Chick Magnet's Avatar
Default stretching tires
im going to buy ssr mesh wheels for my dc2. the wheels are 4x100 15x7 with 10 off-set and im wondering since its 15x7 will i be able to stretch falken ziex or falken azenis tires ?
Old Nov 17, 2006 | 04:21 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: stretching tires (dc2rtek)
For an Integra with 15" wheels, you should get tires that are 195/55-15 or 205/50-15. Both sizes are approved for mounting on rim widths as high as 15x7, so you could mount those tires on 15x7. But you're better off getting 15x6.
However, I don't understand why anyone in Southern California would get Ziex all-season tires, unless you drive your car to places where it snows...
Modified by nsxtasy at 8:20 AM 11/18/2006
Old Nov 17, 2006 | 04:45 PM
old man neri's Avatar
A 10 offset rim? WOW, that will stick out a lot and probably rub. Why such high offset?
Old Nov 17, 2006 | 07:05 PM
waddy41's Avatar
i'd do it if i had an eg...smaller wheel well/smaller car
Old Nov 18, 2006 | 01:21 PM
FalkenSiR's Avatar
Default Re: (waddy41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waddy41 &raquo;</TD></TR><TR><TD CLASS="quote">195-45
i'd do it if i had an eg...smaller wheel well/smaller car</TD></TR></TABLE>
195-45s would be stretched like ****... VW style
Old Nov 20, 2006 | 12:15 AM
vtecsi00's Avatar
Default Re: stretching tires (old man neri)
[ WOW, that will stick out a lot and probably rub. Why such high offset?[/QUOTE]
you mean why such a low offset old man neri
he probably like some people like that look...you are not going to be really stretching those tires on that wheel width...i have run 15x7 with a 205-50r15 with a 35mm offset and looks good and does the job just fine... that offset thou will make it a little bit harder for you to run a 195/55r15 without rubbing on the inside of you fender... you will probably have to run a 195/45r15 or a 195/50r15 to make it work which is not a recommended fitment for your car
Old Nov 20, 2006 | 07:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">A 10 offset rim? WOW, that will stick out a lot and probably rub. Why such high offset?</TD></TR></TABLE>
so it turns better. besides i dont need to worry about running spacers and it looks real hard on a dc2. IMO
rolled my fenders.
i got 33 off-set right now, still not enough.
Old Nov 22, 2006 | 07:35 AM
verycleanhatch's Avatar
would you have problems if you get a tire size that won't be stretched for you wheels.
wheels with stretched tires look so ugly and you aren't even using the width the wheels were designed for.
it just looks funny.
Old Nov 22, 2006 | 01:13 PM
TurboJesse
Guest
Posts: n/a
Default Re: stretching tires (verycleanhatch)
your gonna need like a 155 or something to stretch on 7" wheels....i have 195/45/15's on 15x8's and the stretch isn't anything crazy..
variable
Aug 7, 2010 12:59 PM
5280dc2
Oct 22, 2007 04:58 PM
Mr_Snrub
Jan 22, 2006 06:14 PM
snouka
20
Nov 8, 2004 11:43 PM
turbohappy
Oct 28, 2003 05:08 PM
