running 38 and 42 offset. will it be a problem?
Old Nov 25, 2005 | 10:42 AM
trustbuddy's Avatar
Default running 38 and 42 offset. will it be a problem?
if i run one 42mm offset wheel and three 38mm offset wheels on my car, will this cause a problem?
also/or
run two 42mm on one side of the car and run 38mm on the other side of the car,
how will these options work/not work out?
why do i ask a weird question? i made a huge dent on one of my wheels and i found a guy who can get wheels real cheap. problem is i don't want to spend more money than necessary. don't we all...anyways, imput is appreciated.
Old Nov 28, 2005 | 02:25 PM
CB7.v2's Avatar
if you must do this, you should keep the keep each end (fr/rr) the same. not sure how you would decide what goes in fr or rr.
Old Nov 28, 2005 | 03:34 PM
trustbuddy's Avatar
Default Re: (CB7.v2)
i guess it'll be 42's in the front and the 38's in the rear...not 38's to the left and 42's in the right...haha..
Old Nov 29, 2005 | 01:07 PM
EK45VTi's Avatar
Default Re: (trustbuddy)
This is how IT SHOULD BE DONE if you have rims with different offset
If you have ET38 and ET42, this is how it should be
ET42 - both must be in the front
ET38 - both must be in the rear
Don't ever put one offset to the left side off the car and the other offset to the other side...
Always use rear-front combination...
And always use 2+2 pattern... 2x ETXX and 2x ETYY
matt94z
Aug 7, 2008 05:03 PM
fkncivic
Suspension & Brakes
Sep 22, 2006 11:59 PM
Axis-civic
Jul 19, 2005 08:50 PM
L4NDO
Mar 30, 2003 03:04 PM
bhcvc
May 24, 2002 01:16 AM
