OG San wheels
So are they decent or junk knock offs of Enkei92s?
Also, spec shows 35mm offset, but tirerack states this "Aggressive tuner style wheel fitment! This will require fender and alignment work to fit. The wheel and tire will stick out of the fenders!"
I thought the Stock Del Sols were 39mm offset is 4 mm really going to stick outside the fenders?
Get it I, wasn't considering the extra 1.5 inches of width.
It seems the math does not work on these.
If width = 7 (178 mm) and offset =35mm as listed on site
then backspace should equal 1/2 width + offset or 178/2 + 35=124mm which equals 4.88 inches not 5.35
I believe 5.35 would be an 8 inch wide wheel
I see what you're doing there, and the math is correct, but there are some variables left out. Wheel width is measured from bead seat to bead seat, not from outside lip to outside lip. Backspacing is measured from outside lip to mounting face, so a ~1/2" difference is expected if you're doing the raw calculations the way you did. So it is for sure a 15x7 ET35 with a 5.35" backspace.
From tirerack website
Backspacing, similar to offset, is the distance from the hub mounting surface to the inside lip of the wheel (measured in inches).
He is right, I do see that on the website, but it seems there's some misinterpretation. That sentence refers to the inside lip, but that isn't the bead seat. The inside lip would be the side of the wheel closer to the strut, as opposed to the outside lip, which you can see when the wheel is mounted on the car.
Here's a diagram for you:
And here's a less cluttered version:
