offset?
Old Aug 16, 2011 | 07:02 PM
purplerain11's Avatar
Default offset?
Whats a good offset for a 1992 eg hatch? Im looking to lower the car about 2"
Also with that whats a good tire size that would fit my car nicely. Right now i have a 17 by 7.5 rim, 205 45 tires and about 42 offset. The might be a bit big i think?
Thanks
Last edited by toyomatt84; Aug 16, 2011 at 07:07 PM. Reason: I already warned you about opinion-questions in your previous thread here: http://honda-tech.com/showthread.php?t=2969247
Old Aug 16, 2011 | 07:10 PM
toyomatt84's Avatar
Sanji
Default Re: offset?
If you're not looking to do anything to increase wheel/tire clearance (roll fenders/quarter panels, install flares, etc...) then you are looking at about a 15x7 +35 with some 195/50/15 tires.
If you are willing to do some work to increase tire clearance, you could go with a 15x8 +35 with some 225/45/15's.
Old Aug 16, 2011 | 07:15 PM
Default Re: offset?
Thankyou, that helps out alot. I am unable to roll the rear 1/4s because of rust. The front are rollable haha. I guess my option would be to go to the smaller tire/rim. Thanks so much!
Old Aug 16, 2011 | 07:28 PM
toyomatt84's Avatar
Sanji
Default Re: offset?
If you get a decent tire, you'll be amazed at what that sizing combination will give you in terms of grip and acceleration when compared to your current setup.
Old Aug 17, 2011 | 09:54 AM
doc@tirerack's Avatar
Default Re: offset?
in 15" you'll want to be around 35 to 40 mm offset as stated, if you have to stock with 17" a 205/40R17 would be a little better (@ ET38+) but with the drop you still might rub over big bumps
chrisc543
Apr 16, 2014 11:33 AM
Naudlee
Apr 15, 2009 01:38 PM
HamiltonRex
Oct 9, 2006 04:03 AM
BlazinITR
Feb 10, 2003 06:55 PM
Mr. Vapor
Jul 1, 2002 11:23 AM
