Offset
Old Jun 13, 2006 | 11:46 AM
sniggler316's Avatar
Default Offset
So, I looked through a bunch of posts but I'm still not sure of the answer. If I want
my wheels to tuck better I should go with a higher offset right? Right now I have 205/40/17 with 40 offset and they rub my fenders! I want to lower the car more but my fender is eating my tire.
Old Jun 13, 2006 | 01:56 PM
. L i z's Avatar
Default Re: Offset (sniggler316)
try some 35's... the bigger the series number the taller the tire.
Old Jun 13, 2006 | 03:31 PM
FalkenSiR's Avatar
If you want them to tuck more, go with 45+ offset and a slight drop of course. OR, you may want to try adding some camber, that's what I did.
Old Jun 14, 2006 | 03:10 PM
Moogen Powah's Avatar
Default Re: Offset (fast95eg8)
Have you tried rolling your fenders? And also as mentioned earlier, adding some camber could possibly alleviate your rubbing problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . L i z &raquo;</TD></TR><TR><TD CLASS="quote">try some 35's... the bigger the series number the taller the tire.</TD></TR></TABLE>
If you change the aspect ratio of a tire, you'd also have to change the width of the tire. If you were to change it to a 35, the tire size would have to be in the region of a 225/35/17, which would probably just make the rubbing issue worse, not to mention the cost and availability of tires in this size.
Old Jun 15, 2006 | 02:12 PM
odysseybmx's Avatar
How much is your car lowered right now sniggler?
Old Jun 15, 2006 | 05:42 PM
Default Re: Offset (odysseybmx)
I'm lowered at least 2 inches right now. I am low enough that I can't fit my finger between my tire and wheel well. The sleeves I got are supposed to be able to drop it 4" and I am roughly halfway. I think I will try and dial in some camber fro now but I need to get new wheels anyway, so I will probably go with a larger offset when I get there.
Old Jun 15, 2006 | 06:36 PM
hayabusa160's Avatar
roll the fenders and your straight.
i managed to fit some 215 40 17 with no fender gap.the wheels were a 38 offset
dannythewonder
Honda S2000
Sep 20, 2010 11:19 AM
BRIANxJDM
Honda S2000
Jul 6, 2009 05:58 AM
jdmcrx_echelon
May 30, 2007 05:04 PM
J-HAWK
Mar 8, 2006 09:19 AM
92whiteSi
Mar 8, 2005 07:52 AM
