Do you need an alignment if....
Old Oct 6, 2006 | 12:13 PM
DANgerous's Avatar
Default Do you need an alignment if....
You go from the smaller stock 13x5's to 15x7's keeping the overall stock tire diameter? Basically the tire would be 2 inches wider and I'm wondering if this will cause more wear on the tires if I do not get them aligned. Or do I not have anything to worry about?
Old Oct 6, 2006 | 01:46 PM
FalkenSiR's Avatar
Default Re: Do you need an alignment if.... (DANgerous)
This has really intrigued me because I've heard it makes no difference, but then it is 2" bigger and handling characteristics of the car change too. It would be nice to have a final answer!
Old Oct 7, 2006 | 05:57 PM
dspIS-250's Avatar
you shouldn't need an alignment if wheels and tires are the only things that changed. putting bigger or smaller wheels on a car does not affect the suspension itself. the differences you feel as a result of changing wheels and tires can be attributed to the weight of the wheels and the grip of the new tires. the camber and toe stay the same.
evosix
Suspension & Brakes
May 22, 2009 06:42 AM
visine
Jul 5, 2008 06:35 AM
GloomyX
Apr 30, 2007 12:56 PM
NWA 06 CivCoupe
Honda Civic (2006 - 2015)
May 14, 2006 12:04 AM
jsi
Aug 18, 2004 05:25 PM
