Dc2 high horsepower wheel set-up
Car I may buy is 500 hp. K motor. Boosted.
When I had a ITR years back I ran 16x7 and 215/45/16 all around, I forget the offset. They looked great! I would like to keep fronts and rears same size if I can...
I'm looking for the safest most efficient setup. Wheels coming off car are:
245/50/16 front and 205/45/16 rear, +35 offset and the rims are 8 inches wide. Fronts stick out a good bit.
Will 215/45/16 give me the grip I need with that hp? Maybe 225/45/16 or 215/45/16?
I'm not great with wheel specs. Please help me out!
Thanks!
Thanks!
Sanji
Re: Dc2 high horsepower wheel set-up
Considering I've seen heavier cars with less horsepower spin wider tires then even the 245's you're planning on removing, it'd be a safe assumption that there really won't be a wheel/tire combination out there that you won't spin with. The 245's would be the most ideal out of the options listed, unless you plan on running widened fenders or flares.
