3-5PSI improves performance?
Old Jan 7, 2010 | 12:42 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default 3-5PSI improves performance?
The prioritized suspension performance upgrade list (biggest bang-for-buck):
# optimized tire pressures (usually 3-5PSI higher than OEM rating)
http://forums.vwvortex.com/zerothread?id=2486228
3-5 PSI higher cold?
I would be afraid to go 3-5psi higher for DD.
What do you think?
Old Jan 7, 2010 | 01:08 PM
TunerN00b's Avatar
Default Re: 3-5PSI improves performance?
Higher pressure = reduced contact patch size
Now, increasing the pressure can certainly make the car feel more responsive, as there will be less sidewall deformation as turn in, but max cornering traction and braking distances can suffer if you go too high.
I regularly run higher pressure than Honda specified for an Integra up front. When I ran the recommended pressures, I had underinflated tire wear up front (both shoulders wore faster than the center of the tread). When I auto-x, I run lower pressures than Honda's recommendation, but the pressures I do use were derived from a day of testing with shoe polish on the sidewalls (found the lowest pressure that didn't allow the sidewall to "roll over" under hard cornering). I also use the wrong sized tires for auto-x, and the small stiff sidewall on a 205/40-16 RT-615 Azenis is probably all that allows me to run the lower pressure.
Don't be afraid to adjust pressure in 2 to 4 psi increments to find what works best for your desires, your car, your suspension and tires, and your road conditions. I would recommend not attempting to go lower than 6psi below the recommended pressure, and certainly don't go higher than the tires rated max pressure.
Old Jan 7, 2010 | 01:19 PM
nsxtasy's Avatar
H-T Order of Merit
Keep in mind that Honda varies its recommendations based on their expectations on how the car is going to be used. For example, the Integra GS-R and Integra Type R are both sporty versions expected to handle like a sports car. Honda's recommended inflation pressures of 35 front, 33 rear give the cars very responsive handling. IIRC, the lower Integra models (RS, LS, GS) have lower recommended pressures, in the upper twenties, consistent with their expected mission as economical daily drivers. If you want better handling on an RS/LS/GS, you can easily run higher pressures than recommended; if you want better ride comfort in a GS-R/ITR, you can easily run lower pressures than recommended.
Old Jan 7, 2010 | 01:33 PM
kulo's Avatar
whats a good setup
im running 35F 32R
Old Jan 7, 2010 | 02:36 PM
TunerN00b's Avatar
Originally Posted by kulo
whats a good setup
A "good setup" is the manufacturers recommended pressures as a base, with fine tune adjustments based on preference, wear patterns, tires, and driving conditions.
Meaning, you'll need to find those values for yourself.
Besides, without telling us what car (model, sub-model, and year), tires, suspension, and use case (street daily, street spirited driving, track, strip), no one will be able to make any recommendations.
I mean, I have 1 car that is best with 21/26 psi (manufacturer recommended pressures, which sound absurdly low), another at 38/33, and a third at 32/32...
Old Jan 7, 2010 | 03:11 PM
shwanC's Avatar
^ Truth.
Most times different sized wheels and tires are used on our cars. I've never personally used shoe polish, but I have used cat litter...get the tires hot, and slowly drive over with clean tires to see if any sticks to the sidewalls. This is with 0 degree front camber, very simple. I did this because I didn't know what tire pressure to use on '92 Civic with ITR 16" wheels, 205/45 tire. Around 35 psi in the front is good for me.
Old Jan 7, 2010 | 07:02 PM
1.5Slowmatic's Avatar
raising 3-5psi will increase your MPG because of the decreased contact patch. if your driving on the highway a lot i wouldn't hesitate to raise it
Old Jan 7, 2010 | 08:02 PM
N.Balauro's Avatar
Keep in mind that at the track your tires start out cold.... You want to compensate for expansion as the tires come up to operating tempeture (thus increasing pressure since volume cannot change). Cold pressure /= Operating Temp. Pressure.
Also, tire pressures can be used to alter the handling characteristics of your car. A higher pressure, in the front, reduces understeer - decreasing pressuredecreases oversteer. Increasing pressure in the rear decreases oversteer, vice versa.
Finally, increasing pressure in wet conditions reduces the chance of hydroplaning by "rounding" out your contact patch...
Old Jan 8, 2010 | 12:30 AM
BlackDeuceCoupe's Avatar
HT White Ops
What do you think?
I run my tires @ 50 PSI (cold) and they drive just fine.
The only thing you have to watch for is 'cupping'. Rotating them every 5,000 mi is a must!
Sooo, personally, I wouldn't worry about raising your pressure 3-5 PSI. My tire pressure increases that much, when they warm up... even in the winter.
Old Jan 8, 2010 | 06:47 AM
nsxtasy's Avatar
H-T Order of Merit
That's probably more than the maximum pressure indicated on the sidewall, and if so, it's unsafe. They may "drive just fine" right up to the point when they blow out. Don't do it.
Cupping (a scalloped wear pattern) has nothing to do with the pressure you use. Cupping results from a suspension problem, such as blown shocks, worn bushings, etc., which allows play in the tire's movement instead of holding it so it rolls smoothly down the road.
Old Jan 8, 2010 | 08:12 PM
HT White Ops
Thanks, nsxtasy, but...
I'm running Ziex ZE-512s. The maximum pressure (cold) is 51 PSI.
SOURCE: http://www.falkentire.com/tires_spec...=400&width=750
Cupping (a scalloped wear pattern) has nothing to do with the pressure you use. Cupping results from a suspension problem [...]
Correct (with qualification)!
My ride is lowered, and (yes) the cupping is due to alignment issues. Actually, I've never seen a CiViC that was perfectly aligned (lowered or not) but that's fodder for a different discussion. The thing is, raising the tire pressure exacerbates the cupping, in my experience.
No big deal, as long as i rotate them every 5,000 miles. If I go much over that, the tires never have a chance to recover. They'll bump and shimmy until they're replaced.
Old Jan 9, 2010 | 05:38 AM
alphalanos's Avatar
Thats the max pressure the tire can safely hold. That has nothing to do with performance or handling etc. Its much too high.
Old Jan 9, 2010 | 06:35 AM
A Blue Lude's Avatar
Must have an interesting ride, too.
I've run as much as 50psi (quite) hot in the fronts out of necessity, and that certainly didn't feel ideal...
Old Jan 9, 2010 | 07:45 AM
nsxtasy's Avatar
H-T Order of Merit
Cupping is caused by a suspension component that is allowing play. It is NOT caused by alignment, and it is NOT caused by higher tire pressures.
If you want to eliminate the cupping, get the suspension thoroughly checked out by an expert. Shocks, bushings, and ball joints are common causes.
Yup, exactly. Using 50 psi will give you horrible ride quality, and it will give you WORSE handling (since it reduces the area in which your tires contact the road; it's only two thirds of the contact area you'd have with a normal pressure like 33 psi). But hey, if you want bad ride quality AND poor handling, it's your car, you can do whatever you want with it.
Old Jan 9, 2010 | 11:19 AM
HT White Ops
Must have an interesting ride, too. [...]
Definitely!
If I can expound...
I actually ended up with 2 sets of OEM alloys for my ride - HX alloys (came with the shell) - and Si alloys (from the donor swap car).
I have Pirelli P3000s mounted on the HX rims - and OMG! - it drives/rides like a go-kart @ 50 PSI. They're rated for 44 PSI max, however, I actually went airborne over a railroad track crossing (Dukes of Hazzard Style) at 130 MPH. My fault... I was racing a guy and didn't see them coming! The other guy (in a shower of sparks) almost endo'ed his ride... but my Vic handled it like a champ!
Yes, the Pirellis @ 50 PSI feel like I'm running on solid rubber farm tires, but they handle just fine - if a little skitterish at times.
I have Falken Ziex ZE-512s mounted on the Si rims, and it's a TOTALLY different experience @ 50 PSI. They drive great! Really! My Vic feels like a little BWM with this combo. They felt/drove like mush @ door-sticker pressures!
Anyway, I'm NOT here to argue the point. I'm just saying that increasing your tire pressure 3-5 PSI isn't going to hurt anything, IMHO...
Old Jan 9, 2010 | 11:33 AM
HT White Ops
[...]But hey, if you want bad ride quality AND poor handling, it's your car, you can do whatever you want with it.
LoL!
Truthfully, I up the tire pressure to increase fuel economy, lessen rolling resistance, and increase acceleration.
LoL! I gotta hold the world record for B16A2 gas mileage (Lifetime Mileage: 40.44 MPG).
Proof: http://ecomodder.com/forum/em-fuel-l...vehicleid=1291
Old Jan 9, 2010 | 02:17 PM
nsxtasy's Avatar
H-T Order of Merit
Now I know we can trust your advice.
Old Jan 9, 2010 | 11:41 PM
HT White Ops
Sorry! That ^%$*er just wouldn't give up...
Old Jan 10, 2010 | 06:21 PM
bsmith100's Avatar
Try it out and see what you think. It's easy enough to change if you don't like it.
Adjusting tire pressure is the quickest and easiest tuning method there is. It is also one of the most effective.
Old Jan 11, 2010 | 10:28 AM
HT White Ops
Thank you!
You've crystallized my thoughts exactly!
LoL!
You know... I've been thinking about this thread...
I wonder how many ppl make tire recommendations, based on how well they work... when they're underinflated!?!?!?!
Truthfully, I H-A-T-E-D my Ziex ZE-512s when I first got them. They felt like marshmallows - and I could see why some ppl were trashing them in the threads (including myself)! But, when I boosted the tire pressure to 40-50 PSI, they felt great!
The fact that they're rated for 51 PSI (cold) indicates that they're designed to run at higher pressures... no?
Old Jan 11, 2010 | 01:01 PM
nsxtasy's Avatar
H-T Order of Merit
No. The pressure shown on the sidewall is simply the maximum pressure for which they can safely be used, and is NOT a recommendation for the pressure to use.
Different tires may vary by a few psi, but the big variable in tire pressure is the car, not the tire.
Your car will almost certainly handle better and ride more comfortably, and the tires will wear more evenly and thus last longer, with tire pressure in the thirties than 50 psi.
Old Jan 11, 2010 | 10:32 PM
HT White Ops
No. The pressure shown on the sidewall is simply the maximum pressure for which they can safely be used, and is NOT a recommendation for the pressure to use. [...]
Depends on whom you believe, I suppose...
Source: http://www.hybridcars.com/gas-saving...ic-hybrid.html
Tire Pressure
Tire pressure (i.e., rolling resistance) has a significant influence on fuel economy, and an obvious impact on safety and the quality of your ride. Do the research, and make your own decisions about how far to take the tire pressure to maximize mileage.
Drivers getting the highest mileage recommend using the recommended maximum tire pressure on the sidewalls—not the psi supplied by the automaker on the doorframe.
Maintain the maximum recommended tire pressure. Check the tire pressure regularly so the pressure does not fall below the maximum level.
IMHO, 40-50 PSI is the sweet spot, for a Vic!
Old Jan 12, 2010 | 12:56 PM
nsxtasy's Avatar
H-T Order of Merit
The people who wrote that information are idiots. But there are idiots who post here, too, as some of the posts in this topic demonstrate. You can believe the idiots, or you can believe the experts, such as the Tire Rack.
I've seen some people do things that are pretty darn stupid. Fortunately, I've also seen many more people use common sense as well as the advice of experts. It's your car, and you can decide what to do with it.
Originally Posted by Tire Rack
It is important to note that the maximum load is rated at an industry specified tire inflation pressure that is often lower then the tire's absolute maximum tire pressure. The tire pressures used to determine the maximum load the tire is rated to carry is based on the sizing system industry standards applied to the tire.
However, the tire's maximum inflation pressure may be greater, such as 300 kPa (44 psi) in this example or even 350 kPa (51 psi). This is done to accommodate the vehicle manufacturers desire to tune the tires' high-speed capability, handling qualities and/or rolling resistance to better suit the vehicle.
It is important that owners consult their vehicle's tire information placard (usually found on the driver's door or doorjamb) or their owner's manual for the recommended tire pressures for their vehicle's driving conditions.
Twigster311
Aug 10, 2003 05:31 PM
shadowdawn
Nov 5, 2002 11:21 AM
MooreBoost
Sep 5, 2002 03:26 PM
skyline69
Jan 5, 2002 04:03 PM
