13 in 6 offset front wheels on ef
Old Apr 5, 2014 | 10:58 AM
LuckyJDM's Avatar
these are drag rims that im looking at on craigslist and I want to know if I need wheel spacers to run these im sure ill have to roll my fender, but I dont need camber kits or spacers correct? and im just running the 2 front rims like this with hopefully 205/50 drag radials
stock brakes by the way and my car is not that low
Old Apr 5, 2014 | 02:44 PM
toyomatt84's Avatar
Sanji
Default Re: 13 in 6 offset front wheels on ef
What's the width of the wheels? Is it a +6 or -6 offset?
Old Apr 6, 2014 | 06:40 AM
LuckyJDM's Avatar
+6 and 13x8 I think but im going to text the guy to make sure
Old Apr 6, 2014 | 08:11 AM
toyomatt84's Avatar
Sanji
The width is crucial since the "offset" measurement is from the CENTER of the wheel. Without knowing the width, the offset measurement means nothing.
Old Apr 6, 2014 | 09:27 AM
LuckyJDM's Avatar
13x8 is confirmed so can I run these? w/o wheel spacers or camber kit? ill roll my fenders
Old Apr 6, 2014 | 11:08 AM
bamaland601's Avatar
i dont think you will need spacers.. camber kit probably so..
Old Apr 6, 2014 | 12:22 PM
toyomatt84's Avatar
Sanji
Are you just running them for the track? If so, why should it matter if they clear? Run a much wider tire then a 205 on the wheels, and get a better footprint.
Also, running negative camber on a drag setup? Why? For Drag cars, 0 degrees of camber is the most ideal setup. You don't want to limit your contact patch at all.
Old Apr 6, 2014 | 04:27 PM
LuckyJDM's Avatar
this is my daily driven car its a street car, and no im not saying i want to run camber kits but some wheels you have to run camber kits to fit the wheel and usually they dont make drag radials for 13s that are bigger then 205 but if i find some I will get 225 anyways my original question... Will I be able to run drag rims that are 13x8 +6 offset on stock brakes on my ef with rolled fenders but no camber kits or spacers??? Only running the front 2 wheels
Old Apr 6, 2014 | 07:54 PM
toyomatt84's Avatar
Sanji
I am confused as to why you would run drag radials on a daily driven street car. That's a horrible waste of money, since drag radials do not have a long treadlife at all.
Seeing as though I have no idea what design of wheel this is, I cannot give an honest answer as to whether or not they'll clear your brakes. They MAY clear, they may not. Furthermore, they won't clear your fenders unless its an aggressive fender roll.
WannaRun??
Jul 14, 2012 08:20 PM
meric0786
Jul 10, 2011 11:16 AM
messeduprex
Acura TSX
Jun 26, 2010 09:12 AM
Tarmac Junkie
Nov 19, 2008 03:29 PM
hybridb18
Apr 20, 2004 12:32 PM
